64s 83 #1 Posted May 18, 2009 I have an RJ that doesn't have the serial tag or original engine so I know iding is difficult, but maybe others have some of the 'clues' I might have. 1- Solid seat pan 2- Raised stamped numbers/letters on trans by shifter 3- Appears to have glue residue -oval shaped- on top of trans (right rear) 4- Spirial bound lift cable tube Everything else appears to be identical to either a 58 or 59. Does anyone have a strong feeling as to a year? Thanks!! George :omg: Share this post Link to post Share on other sites
64s 83 #2 Posted May 20, 2009 Anyone???? Was there suttle changes made between the 58 and 59? Or are they 100% identical twins? :omg: Share this post Link to post Share on other sites
Jim_M 179 #3 Posted May 20, 2009 I don't know of any difference between a 58 and a 59. Could you post a picture or two of your tractor? Share this post Link to post Share on other sites
HorseFixer 2,013 #4 Posted May 21, 2009 Well yeah this is no doubt a tuffy without engine and so forth. Since it has the stamping on the tranny that means that it is a later in the year 58 so I have been told. A lift sector (multiple sector) they say is a 59. Also a 59 most likley has a toolbox and fenders. An engine model and spec # sure would have helped have any pictures you could post? :omg: Share this post Link to post Share on other sites
64s 83 #5 Posted May 21, 2009 Unfortunately I can't get to it to take pictures, but does anyone have an RJ with a solid seat, and if so, what year? Was a solid seat factory built? All of the Wheel Horse info I have shows perferated seats thru 61. Also, it doesn't have a toolbox or fenders or the lift selector, but I've been told that all were options. Overall the tractor appears to be original (except for the engine) - or pieces were changed a long time ago. Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #6 Posted May 21, 2009 The "legend" goes that the RJ-58/59, 400, & 401 models did not have the toolbox and fenders as standard equipment and were an option (FA-58 for 1958 models) that cost approximately $9.95. The 550 had the battery in the toolbox so it was required on that model and I have yet to see a 551 without the toolbox/fender assembly either. The multi-position lift lever quadrant was actually required for the "new" RMR-32 mower in 1960 and MIGHT have been installed on some of the last RJ-59's to be sold if they were fitted with the new-style mower. It's my understanding that it's pretty much a "bolt-on" retrofit on the '58/'59 tractors. There is also talk that some 1959 models that were equipped with a solid pan seat. (possibly a supplier conflict or other issue?) No one really knows what the dealers did to these tractors as the consumers saw the advancements and upgrades in the newer models and demanded/requested their tractors to be equipped with "modern" accessories or convenience items. (Look at how many 1968 500 Special tractors are out there with electric start, etc.) Share this post Link to post Share on other sites
