71_Bronco 1,072 #1 Posted October 14, 2020 So I've seen many videos / articles about "flattening" a Kohler head before installing a new head gasket. I assume this process should be done no matter what the engine brand is, correct? I'm working on a S7D Wisconsin (single cylinder, 7HP), and it will be getting a new head gasket (preventative, not due to a blown gasket). This engine has a similar cast-iron block and aluminum head like the Kohlers do. I was planning on doing it anyways, figured it couldn't hurt. Thoughts? 2 2 Share this post Link to post Share on other sites
ebinmaine 80,767 #2 Posted October 14, 2020 If nothing else I would take some finer grade paper like 400 or so and at least make a few passes with the head on the paper to see if you have any nasty highs or lows. 2 Share this post Link to post Share on other sites
oliver2-44 11,758 #3 Posted October 14, 2020 Yep, flatten every brand Share this post Link to post Share on other sites
71_Bronco 1,072 #4 Posted October 14, 2020 1 hour ago, ebinmaine said: If nothing else I would take some finer grade paper like 400 or so and at least make a few passes with the head on the paper to see if you have any nasty highs or lows. That sounds like a good idea. I may hit it with sharpie first, and do a test cut with something fine. If no high / low spots, I wont have to do a major resurface 2 2 Share this post Link to post Share on other sites
ebinmaine 80,767 #5 Posted October 14, 2020 4 minutes ago, 71_Bronco said: That sounds like a good idea. I may hit it with sharpie first, and do a test cut with something fine. If no high / low spots, I wont have to do a major resurface Excellent idea Share this post Link to post Share on other sites
pacer 3,180 #6 Posted October 14, 2020 Yeah, its too simple a thing not to take the few mins to give it a check. As mentioned, use wet/dry sandpaper 4-500 grit or more and find the flattest place you can - plate glass is best (if you dont have a granite plate$$) Wet the paper with some type of oil - kerosine, thinner, WD40, etc and rub her around a bit......... Share this post Link to post Share on other sites
bottjernat1 2,197 #7 Posted October 14, 2020 I found this hope this helps 1 Share this post Link to post Share on other sites
lynnmor 9,042 #8 Posted October 14, 2020 I have a vertical bandsaw with a ground table that works well. Keep in mind that not all glass is perfectly flat and some glass will bend a bit. If you are doing two or more heads, lay the lapped surfaces together and check for daylight between them or use a feeler gauge, you might be surprised to see that your newly lapped heads are not as flat as you thought. 1 Share this post Link to post Share on other sites
stevasaurus 23,857 #9 Posted October 14, 2020 Check out this thread... Looking at the video that Nate offered, I don't like that the guy mounted his glass on chip board. A saw table would be a much better choice. You need a solid, flat surface for the glass. 1 Share this post Link to post Share on other sites
richmondred01 2,393 #10 Posted October 15, 2020 2 1 Share this post Link to post Share on other sites
WHNJ701 4,173 #11 Posted October 15, 2020 On 10/14/2020 at 10:03 AM, 71_Bronco said: That sounds like a good idea. I may hit it with sharpie first, and do a test cut with something fine. If no high / low spots, I wont have to do a major resurface Just use spray paint before you sand them it 2 Share this post Link to post Share on other sites
