Horse Newbie 6,912 #1 Posted October 11, 2020 Can someone who has worked on the Onan P220G engine before give me an idea of whether these exhaust gasket surfaces look clean enough to reassemble ? ( see pics) And also would you use gasket sealer on them or just the gaskets ? Share this post Link to post Share on other sites
WVHillbilly520H 10,369 #2 Posted October 11, 2020 4 hours ago, Horse Newbie said: Can someone who has worked on the Onan P220G engine before give me an idea of whether these exhaust gasket surfaces look clean enough to reassemble ? ( see pics) And also would you use gasket sealer on them or just the gaskets ? Where is your pics? Share this post Link to post Share on other sites
Horse Newbie 6,912 #3 Posted October 12, 2020 1 hour ago, WVHillbilly520H said: Where is your pics? Right here...I seen them here before...who knows...I think I may have posted them and then deleted...lolol 1 Share this post Link to post Share on other sites
onanparts.com 178 #4 Posted October 12, 2020 Look good! No sealer required. If possible it's best to use new grade 8 bolts and coat the threads with anti seize or at least some oil if anti seize is not available. 1 1 Share this post Link to post Share on other sites
Horse Newbie 6,912 #5 Posted October 12, 2020 6 hours ago, onanparts.com said: Look good! No sealer required. If possible it's best to use new grade 8 bolts and coat the threads with anti seize or at least some oil if anti seize is not available. Thanks #Onanparts.com ! Share this post Link to post Share on other sites
