Tractor Jim 0 #1 Posted May 17, 2009 :omg: Can some one tell me what year thie RJ is. Thank you, Tractor Jim Attached Image Share this post Link to post Share on other sites
C-Series14 15 #2 Posted May 17, 2009 1958-1959. I am gonna guess 1958. The experts will give you a better answer... :omg: Share this post Link to post Share on other sites
oldandred 16 #3 Posted May 17, 2009 its hard to tell with out the tag on the chassie just behind the front wheel it could be a 59or58 both looked the same and were the same Share this post Link to post Share on other sites
wheelhorsecravins 0 #4 Posted May 17, 2009 :omg: I see you found your way to redsquare, now you can look for parts and there is a lot of great people on here that are very knolageable???? well you know my spelling, anyway have fun and add pictures as you go, if you can't fix it give it to me!!!!!!!!!!!!!!!!!!mike Share this post Link to post Share on other sites
HorseFixer 2,015 #5 Posted May 17, 2009 Do ya think you can make that picture just a little smaller? That way I could get out my eLeCtRoN mIcRoScOpE out and give it a lOOk See! by the way :drool: Share this post Link to post Share on other sites
Tractor Jim 0 #6 Posted May 18, 2009 RJ the one that got away. There was a sticker on the frame that shows RJ - 58. My brother thinks it's older because the front axel is stright and thinks it might be a RJ - 35 and if some one knows where I can get spec. on the rear axel that would be nice. Thank you, Tractor Jim Attached Image Share this post Link to post Share on other sites
CasualObserver 3,417 #7 Posted May 18, 2009 The straight tube steel axle was also on the RJ-58 and RJ-59. The cast iron axle was started with the 1960 models. The RJ-35 was a belt tension variable speed drive, not a gear drive tractor like yours is. The RJ-58 tag is most likely correct. Take a look in the gallery to see examples of both. Shorcut link to the 1955-1964 gallery Share this post Link to post Share on other sites
