Scotsman 46 #1 Posted October 8, 2020 Is there a way to remove hubs from my 518-H without a puller? I didn’t see any previous threads about It thanks by the way.... I am excited for snow blowing season!! am I sick? 1 Share this post Link to post Share on other sites
pfrederi 21,050 #2 Posted October 8, 2020 Not really unless the are very loose. Lots of homemade puller ideas on here. Any attempt to yank it off or drive it off from behind risk breaking the hub or even worse pulling the axle out as it is only held in by a snap ring. As to snowblowing season yes you are 1 Share this post Link to post Share on other sites
953 nut 68,509 #3 Posted October 8, 2020 3 hours ago, Scotsman said: I am excited for snow blowing season!! am I sick? You'll get over it! As for the hub, here is a puller that will get the job done without too much problem. 1 1 Share this post Link to post Share on other sites
Scotsman 46 #4 Posted October 10, 2020 Thanks pfrederi for the heads up👍 953 nut I love the bottle jack pick of Meadowfields brilliant way to draw it out And extra points for using stuff I have laying around A Scotsman’s dream😁 Share this post Link to post Share on other sites
Scotsman 46 #5 Posted October 11, 2020 (edited) I cant find my jack so looks like I’m going to Harbor Freight there stuff is lousy quality but it’s cheap for something I may never use again But I’ve got the 1100 on anyway Scotsman🦉 Edited October 11, 2020 by Scotsman Share this post Link to post Share on other sites
Scotsman 46 #6 Posted December 16, 2020 (edited) Well Luckily the axle of my rebuilt Eaton 1100 didn't have hubs on it . I tried removing my old hubs, and I can tell you how not do it. I bought the smaller hub puller from Harbour freight,the tourque bent the connecting brackets ! So I bought the biggest they had,and I snapped my hub in two ! So lucky for me the hubs are used on a variety of Wheel Horse tractors. So I found a pair on eBay from a c175 if I remember for 49$ with free shipping! The big hub puller cost 90$ so I returned it. Problem solved. I would recommend penetrating solvent and a plumbers torch which is 10$ Just heating the hub will expand it and allow it to be tapped off with two hammers tapping at 12-6 then 3-9 on the clock respectively for a slow removal. Now I have to hook up the tranny lines and install all the Eaton 1100 hydro stuff after removing the electric PTO stuff Not to mention putting onhe wheel weights and snowblower Boston is getting 10 15 inches tonight It's tall order to get that all done today I may be using my toro walk behind Edited December 16, 2020 by Scotsman Share this post Link to post Share on other sites
pfrederi 21,050 #7 Posted December 16, 2020 Tapping hubs off with hammers may work but it is risky. Too easy to pull the axles out as it is only a snap ring holding it in the tranny Share this post Link to post Share on other sites
wallfish 20,510 #8 Posted December 16, 2020 Safer to use the penetrating oil and the torch in conjunction with the puller instead of going directly to hammer on the hubs. Removing the set screw completely to load oil directly in that hole helps too. Use the hammer to hit the threaded rod piece of the puller to shock it loose. And some of those need more patience then others too. The cast hubs are hard but also brittle. Share this post Link to post Share on other sites
