sexontoast 0 #1 Posted October 8, 2020 (edited) Hey Everyone, I have a 212-5 wheelhorse that needs a new belt, though in Australia I have found only 1 company that will sell it.. and its expensive $250AUD (Approx. $180usd) Now I found a seller that also mentioned the belt 113169 also matches the John Deere M126536. Problem is, only 1 seller has mentioned this so its a bit harder to take their word on it, so I am hoping someone here can either direct me to somewhere in Aus or the states to purchase it (without prohibitive shipping) or verify its the same belt as the John Deere Now to confuse things further, The toro part number 113169 covers 2 models at different sizes 112" & 115" 113169 1/2" W x 112" L (inside) 113169 1/2" W x 115" L (inside) Pretty sure mine matches the 112" and the 115" is for a product 3536AL01 (Cannot find any info on what this is) If mine is the 112" then it looks like the John Deere part is the go. Thanks in Advance Edited October 8, 2020 by sexontoast Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,757 #2 Posted October 8, 2020 Welcome to the forum. Our records show the 113169 belt to be 1/2" x 116" but that is measured around the outside of the belt. Click on the picture Here is a dealer that seems to have the most reasonable prices. https://www.psep1.biz/arinet.asp#/s/TO//113169/1/ If you click on "Select Model" a list of the parts lists that have the 113169 part number come up. Garry 1 Share this post Link to post Share on other sites
ebinmaine 74,664 #3 Posted October 8, 2020 As long as that's a regular rubber sided standard v belt my own inclination would be to remove it and bring it to a good quality old school auto parts store that understands how to properly measure a belt. 2 Share this post Link to post Share on other sites
953 nut 62,272 #4 Posted October 8, 2020 In the US we have a company named Tractor Supply which carries a wide selection of belts and you can bring your old belt in to match it up to a new one. Perhaps you have a similar company. The belt you need will be fabric wrapped and may also be found at an industrial supply sales house. Belts with a raw rubber edge will tend to grab when the clutch is being released. 1 Share this post Link to post Share on other sites
squonk 44,672 #5 Posted October 8, 2020 If that belt is similar to the one on my 210-H then no it is not a normal v belt. Share this post Link to post Share on other sites
peter lena 9,471 #6 Posted October 8, 2020 are you located anywhere near a farmer or ,related supply source? bring the belt and all related info ,with you , you should be able to get a lead on getting the belt , pete Share this post Link to post Share on other sites
sexontoast 0 #9 Posted October 9, 2020 (edited) Thanks for the help, Might have to remove it and take it in and grab an additional belt to have on hand, since parts are becoming hard to source. Also have a husky zero turn, 20 hours been in the shop 4 times for issues already... where the wheelhorse "touch wood" has been unbreakable so far. Also are the oil filters agnostic to the motor (onan / kaw etc) for this model, or could the motor change which one is required. Not sure which motor this one has 12.5hp 2x serial Edited October 9, 2020 by sexontoast Share this post Link to post Share on other sites
ebinmaine 74,664 #10 Posted October 9, 2020 6 hours ago, sexontoast said: where the wheelhorse "touch wood" has been unbreakable so far You'll find with proper maintenance intervals a Wheelhorse is tough to beat. Not sure on the oil filters. @gwest_ca ? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,757 #11 Posted October 9, 2020 The 212-5 used Briggs and Stratton, Kawasaki and Onan engines so model numbers required to determine the correct oil filter. Garry Share this post Link to post Share on other sites
