tallen4392 71 #1 Posted October 4, 2020 Can anyone tell what pieces I am missing to attach the lift arm to the plow frame ?? Share this post Link to post Share on other sites
ebinmaine 79,702 #2 Posted October 5, 2020 Short lift link. 5 or 6 inches long. A little chain. Allows for blade float. Or Long lift link. 11.5 or so long. Creates down pressure on the blade. 2 Share this post Link to post Share on other sites
tallen4392 71 #3 Posted October 5, 2020 Short lift link is that a wheelhorse part ?? Share this post Link to post Share on other sites
tallen4392 71 #4 Posted October 5, 2020 Is it the same for all models or does it have to be for my charger Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,357 #5 Posted October 5, 2020 Back in the day the blade for your tractor came in two packages. The blade in one and the frame to suit the tractor it was going on. The lift links came with the blade and are illustrated in the manual. Your tractor is a long frame model and the last blades sold up until a few years ago would still fit your tractor. Garry 2 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,357 #6 Posted October 5, 2020 Back in the day the blade for your tractor came in two packages. The blade in one and the frame to suit the tractor it was going on. The lift links came with the blade and are illustrated in the manual. Best to click on the pictures below and download from that page. Your tractor is a long frame model and the last blades sold up until a few years ago would still fit your tractor. Garry 1 Share this post Link to post Share on other sites
tallen4392 71 #7 Posted October 5, 2020 Thanks Garry lot of good info u would think someone on here would have one to sell me .... Share this post Link to post Share on other sites
tallen4392 71 #8 Posted October 5, 2020 Could I just use a piece of chain 3 Share this post Link to post Share on other sites
Pullstart 70,714 #9 Posted October 5, 2020 Sure could, that would give you lift and float 1 Share this post Link to post Share on other sites
Pullstart 70,714 #10 Posted October 5, 2020 Clevis. That’s the word I’m looking for! A couple clevis’ for the chain ends would allow easy hookup. 1 Share this post Link to post Share on other sites
ebinmaine 79,702 #11 Posted October 5, 2020 10 hours ago, tallen4392 said: Could I just use a piece of chain I don't see why that wouldn't work as long as the lift angle worked out okay. Forgive me if I missed it but is this on a tractor with a hydro lift? Share this post Link to post Share on other sites
tallen4392 71 #12 Posted October 5, 2020 no hydro lift... wish it was Share this post Link to post Share on other sites
Achto 32,095 #13 Posted October 5, 2020 11 hours ago, tallen4392 said: u would think someone on here would have one to sell me .... The using just a chain will work without issue. If you wish to have a solid link for down pressure they are easy to make. I can get you dimensions tonight, unless someone beats me to it. 1 Share this post Link to post Share on other sites
Achto 32,095 #14 Posted October 5, 2020 2 minutes ago, tallen4392 said: no hydro lift... wish it was Chain will work best then. 1 Share this post Link to post Share on other sites
ebinmaine 79,702 #15 Posted October 5, 2020 Neither one of our current plow tractors are hydraulic lift. Both of the plows we use have a solid link. It gives you the capability of pushing forward on the lever to generate some downforce for scraping up areas like where you may have driven over the snow and compacted it. 2 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,357 #16 Posted October 5, 2020 The long solid link works well for a manual lift. If you leave it alone the lift lever moves on it's own to give you float. Hydraulic lift won't do that. Garry 1 Share this post Link to post Share on other sites
Achto 32,095 #17 Posted October 6, 2020 If you have the means to make a solid lift bar here are the dimensions. A piece of 1/4" x 1 1/4" flat stock 12 1/2" long. Weld 3/8" pins 11 1/2" on center apart. 1 1 Share this post Link to post Share on other sites
tallen4392 71 #18 Posted November 27, 2020 I have a 308 8 speed also the lever under that is curved like in just about all the pics I see but the charger hookup is up inside between the frame like in the picture very different than most I see and very different than my other tractor something is missing I think on this charger I don't think I could put a piece of chain from that piece in the picture to the plow frame bracket it would have to be 10 inch piece of chain what am I missing I put the blade under it today I will snap a few more picture tomorrow Share this post Link to post Share on other sites
tallen4392 71 #19 Posted November 27, 2020 I am trying to put the plow from the 308-8 onto the charger 12 ?? Share this post Link to post Share on other sites
ebinmaine 79,702 #20 Posted November 27, 2020 9 hours ago, tallen4392 said: I will snap a few more picture tomorrow That would be helpful. I'm thinking you have the same setup we do here. I remove the curved piece on assembly of our tractors because we don't use any mowers. You'll likely use the connection right at the rock shaft and go directly to the plow. Either 5" solid with the rest chain to give float or a full solid bar to give down pressure. Share this post Link to post Share on other sites
tallen4392 71 #21 Posted November 27, 2020 From stuff I have read these chargers are a different animal when it comes to attachments I can't just take the deck off my 308 and put it on the charger won't work that is why this charger plow hookup is totally different no long curved horizontal link under it they are both long frame models but the directional lever to turn the plow is right up against the floorboard on the charger but not on the 308 I am beginning to believe this is not interchangeable with the two machines anyone have a charger without hydro lift that could snap a pic of the lift system under there machine .. ( pics of mine to follow ). Share this post Link to post Share on other sites
ebinmaine 79,702 #22 Posted November 27, 2020 1 hour ago, tallen4392 said: beginning to believe this is not interchangeable with the two machines anyone have a charger without hydro lift that could snap a pic of the lift system Any LONG frame plow from 1967 up will fit. A 308 and a HORIZONTAL engine Charger are both long frames. It isn't IF it will fit, it's what may have been or need to be changed over the years. The rock shaft for the lift is in the same place whether hand lift or hydro lift. I've had the same issue on my Cinnamon Horse with the angle lever hitting the right hand floor board. I never did find an explanation for it. I tried both a 42" and 48" plow and both were the same. I ended up fabbing a bracket for the plow that mounted differently than stock and moved the plow forward 2". When you get some pics of your own setup we can see where the specific interference is and correct it. Share this post Link to post Share on other sites
tallen4392 71 #23 Posted November 27, 2020 6D5ECF3C-1D80-4486-A021-983E176C6F3A.heic B9AF8879-C7A7-4C38-93F8-9CE611D81D2E.heic 7E6AD550-4204-40F7-8411-D86D5910C23C.heic 3C8478FB-F075-437F-8D93-8C0C818841F7.heic Share this post Link to post Share on other sites
ebinmaine 79,702 #24 Posted November 27, 2020 I can't open those files in my phone. Maybe someone with a pc can switch them over to a file type that will post. Share this post Link to post Share on other sites
tallen4392 71 #25 Posted November 27, 2020 I don't know if the pics went through the one with the horizontal arm is the tractor the plow was on everything worked but the others are the charger very different hook up two small arms on the shaft that's it but if I can't get the lever to go all the way when turning the plow left then I will have to come up with a different plan ..... I don't have a welder..... Share this post Link to post Share on other sites
