snowhound 106 #1 Posted October 4, 2020 In Sept. we had a new paved driveway put in the driveway has a fairly steep hill. In the past I've used turf tires with chains on my snow blower tractor but am concerned about damaging the new pavement would bar tread tires give me decent traction? I have cast iron weights and I go about 200 lbs. Share this post Link to post Share on other sites
ebinmaine 79,689 #2 Posted October 4, 2020 Ag tires won't be satisfactory to you especially in a hill. What you need are RUBBER CHAINS. And tons of weight. Enough weight? Add more. @Ed KennellKennell is it you that runs rubber chains? 4 Share this post Link to post Share on other sites
AMC RULES 37,259 #3 Posted October 4, 2020 Ags are probably the worst choice for traction in the snow. https://www.millertire.com/products/lawn-garden-tires/23x10-50-12/23x10-50-12-carlisle-all-trail/ 2 Share this post Link to post Share on other sites
AMC RULES 37,259 #4 Posted October 4, 2020 https://www.millertire.com/products/lawn-garden-tires/23x10-50-12/23x10-50-12-kenda-terra-trac-4-ply/ 1 Share this post Link to post Share on other sites
doc724 927 #5 Posted October 4, 2020 Regular chains will scratch your driveway of you spin the tires. I would stay away from bar tread chains. Of course, if you are using a blower, there should be less spinning than if you are using a plow. My driveway was not very steep, but I would put on cast iron weights and four 40 lb suitcase weights and chains and me had no problem with wheel spinning with a blower. Share this post Link to post Share on other sites
AMC RULES 37,259 #6 Posted October 4, 2020 Beet juice...filled tires all four corners. Share this post Link to post Share on other sites
ebinmaine 79,689 #7 Posted October 4, 2020 15 minutes ago, AMC RULES said: Beet juice...filled tires all four corners. Yessir. Like my Cinnamon Horse has. 1 Share this post Link to post Share on other sites
pfrederi 20,870 #8 Posted October 4, 2020 I use rubber chains and a plastic edge on the plow for eh short length of drive with pavers. Rubber chains work well (not as good as steel) but they pound you as they are really 4 link. equivilent. 2 Share this post Link to post Share on other sites
Racinbob 13,040 #9 Posted October 4, 2020 We have a long blacktop drive. I use 150# of wheel weights, a weight box hooked to a 2" receiver hitch and rubber chains on the tractor with the blade. The blower tractor has 110# of wheel weights and that's it. So far no issues with either but last winter wasn't a test. 1 Share this post Link to post Share on other sites
Ed Kennell 46,583 #10 Posted October 4, 2020 1 hour ago, ebinmaine said: Ag tires won't be satisfactory to you especially in a hill. What you need are RUBBER CHAINS. And tons of weight. Enough weight? Add more. @Ed KennellKennell is it you that runs rubber chains? Yep, I believe the rubber straps actually twist and act like a cut pulling tire when in loose snow. And they have better traction than steel on a bare paved driveway. Steel is better on ice. Weight=Traction 2 2 Share this post Link to post Share on other sites
WVHillbilly520H 10,378 #11 Posted October 4, 2020 (edited) 7 hours ago, ebinmaine said: Ag tires won't be satisfactory to you especially in a hill. What you need are RUBBER CHAINS. And tons of weight. Enough weight? Add more. @Ed KennellKennell is it you that runs rubber chains? Eric, I'm gonna have to disagree with you here , I have AG tires on my 520s fluid filled and iron weights plus a little more hanging out back of the snow chucker rig and DON'T use chains on our paved driveway without issues (of course your milage may vary)... my OTR Lawn Trac R1 has been an excellent traction tire on my 2 520s whether the blower or pushing a 56" snow plow or pulling a 10" Brinly or mowing my steep hills. Just my experiences here. VIDEO0124.mp4 VIDEO0125.mp4 Edited October 4, 2020 by WVHillbilly520H 3 Share this post Link to post Share on other sites
WVHillbilly520H 10,378 #12 Posted October 4, 2020 7 hours ago, AMC RULES said: Ags are probably the worst choice for traction in the snow. https://www.millertire.com/products/lawn-garden-tires/23x10-50-12/23x10-50-12-carlisle-all-trail/ I respectfully disagree see above. 1 Share this post Link to post Share on other sites
ebinmaine 79,689 #13 Posted October 4, 2020 Mine were pretty slippery without chains. But maybe if I added more weight....? Share this post Link to post Share on other sites
WVHillbilly520H 10,378 #14 Posted October 4, 2020 4 minutes ago, ebinmaine said: Mine were pretty slippery without chains. But maybe if I added more weight....? IDK, I only have 5 gallons methanol in each tire maybe 75# iron each wheel. Then add the cab and another 120# on the blower tractor plus my 200... But the OTR (#2) have a different pattern than the Carlisle TruPower(#1) or Deestone equivalent(#3) that I had to run chains with, again just my experiences. 1 1 Share this post Link to post Share on other sites
ebinmaine 79,689 #15 Posted October 4, 2020 Maybe those OTR are the difference? Interesting straight spot in the center. Share this post Link to post Share on other sites
WVHillbilly520H 10,378 #16 Posted October 4, 2020 16 minutes ago, ebinmaine said: Maybe those OTR are the difference? Interesting straight spot in the center. That center could be the tractive difference IDK... but no chains for 3 years they are definitely better than the Carlisle Trac Chief R4s on my Mahindra and even with fluid fill the sidewalls have plenty of flex. Share this post Link to post Share on other sites
ebinmaine 79,689 #17 Posted October 4, 2020 17 minutes ago, WVHillbilly520H said: That center could be the tractive difference IDK... but no chains for 3 years they are definitely better than the Carlisle Trac Chief R4s on my Mahindra and even with fluid fill the sidewalls have plenty of flex. Forgive the slight side track of the thread here.... How's the mud traction? Share this post Link to post Share on other sites
WVHillbilly520H 10,378 #18 Posted October 4, 2020 Just now, ebinmaine said: Forgive the slight side track of the thread here.... How's the mud traction? So far here in my wet red clay soil gardening this summer no issues a few times I wondered if I was going to have to get a tow but they pulled on through or backed out and over I am truly impressed by this brand tire they can be had in 26x12-12 as well. 1 Share this post Link to post Share on other sites
WheelhorseBob 1,550 #19 Posted October 5, 2020 The limiting factor here is the open differential rear ends these tractors utilize. On ice, no amount of weight or tire tread design will help. What you need is a device that digs into the ice. V-bar chain is the best. Different tires and rubber chains will work if you have dirt or pavement under the snow but as anyone in the snow belt who works for a living knows, by the time you get home after a snow/rain/ice storm the damage is done. I’ve spun the wheels on my F250 plowing our driveway because of ice. That’s with a locked diff and 4x4. Moral of this story, ice doesn’t care about tread design or weight! 4 Share this post Link to post Share on other sites
KrazeyOlDave 860 #20 Posted October 26, 2020 On 10/4/2020 at 6:50 PM, WVHillbilly520H said: IDK, I only have 5 gallons methanol in each tire maybe 75# iron each wheel. Then add the cab and another 120# on the blower tractor plus my 200... But the OTR (#2) have a different pattern than the Carlisle TruPower(#1) or Deestone equivalent(#3) that I had to run chains with, again just my experiences. I’m wanting to fill mine with whatever is the cheapest but will not rust my rims, suggestions? Also, how wide are those rims? I could only find 10.5’s. 1 Share this post Link to post Share on other sites
WVHillbilly520H 10,378 #21 Posted October 26, 2020 7 minutes ago, KrazeyOlDave said: I’m wanting to fill mine with whatever is the cheapest but will not rust my rims, suggestions? Also, how wide are those rims? I could only find 10.5’s. Rims are factory 520H and come in at 8.5" wide for a 10.50" wide tire there are some brand new ones on eBay but back spacing will be of a concern if Wheel Horse ... Mine are filled with methanol that farm shops use, but you could use RV antifreeze (the pink stuff) Or plain old blue windshield washer fluid. 1 1 Share this post Link to post Share on other sites
WVHillbilly520H 10,378 #22 Posted October 26, 2020 On 10/4/2020 at 8:32 PM, WheelhorseBob said: The limiting factor here is the open differential rear ends these tractors utilize. On ice, no amount of weight or tire tread design will help. What you need is a device that digs into the ice. V-bar chain is the best. Moral of this story, ice doesn’t care about tread design or weight! I agree 100%, but also with these GTs in my experiences a hydro trans has big advantage over a gear jammer in the snow/ice you are never in the wrong gear slow fast or just right. 2 Share this post Link to post Share on other sites
ebinmaine 79,689 #23 Posted October 26, 2020 1 hour ago, WVHillbilly520H said: Rims are factory 520H and come in at 8.5" wide for a 10.50" wide tire there are some brand new ones on eBay but back spacing will be of a concern if Wheel Horse ... Mine are filled with methanol that farm shops use, but you could use RV antifreeze (the pink stuff) Or plain old blue windshield washer fluid. Check if you have a Rimguard dealer near you as well. I can get tires filled with Rimguard for less than pink rv antifreeze most of the year. Location. Location. Location. 1 Share this post Link to post Share on other sites
Ed Kennell 46,583 #24 Posted October 26, 2020 15 minutes ago, WVHillbilly520H said: a hydro trans has big advantage over a gear jammer in the snow/ice you are never in the wrong gear slow fast or just right. Yes sir, about a 10X advantage if you are clearing smaller obstructed driveways where you changing directions constantly. 2 Share this post Link to post Share on other sites
midpack 1,147 #25 Posted October 26, 2020 I got a set of rubber chains to keep from tearing up the paved driveway with steel. They work well except on ice. I have about 115#'s on each rear wheel, 30#'s on each front and 200+ #'s in the seat 😆 1 Share this post Link to post Share on other sites
