probe123 2 #1 Posted September 24, 2020 I have a 314-8 and a 416-8 and need to know if the snowblower and snow blade are interchangeable. Thanks, Pat 1 Share this post Link to post Share on other sites
kwalshy 258 #2 Posted September 24, 2020 Yes. Attachment Interchange Share this post Link to post Share on other sites
peter lena 9,943 #3 Posted September 24, 2020 PROBE123, NOT ONLY WILL THEY FIT, but at the time LUBRICATE ALL FRICTIONAL MOVING POINTS , LIKE THE DRIVE CHAIN ON THE SNOW BLOWER ,adjustment on lower outside of the lower sprocket area, there is a horizontal slot . mabey a 1/2" flex while running, also lubricate the chute swivel base and related adjustment arm points. the pto drive belt tension frame spring area just behind blower , lubricate all movement points, for easier operation. on the snow blade lubricate the front end blade swivel area , and also the lever swing arm points , also use hair pin clips , on the levers to your rear axel hook up , to prevent frame drop. all the lubrication will make for easier using equipment , do not struggle with rust , lubricate it , anything else , just ask the site, pete Share this post Link to post Share on other sites
