Scott24 2 #1 Posted September 18, 2020 Hello, I have a 314-H, Model Number 73403 with a Kohler engine M14-601559. While trying to replace the spark plug module (a mouse chewed through the wire) I snapped off the left bolt head. I was able to drill it out and tap it. I then decided to go just a hair bigger and while tapping the new hole I broke the tap. I have tried different tap extractors as well as trying to weld a nut onto it, but have had no luck getting it out. I have looked for a new bearing plate, but it was discontinued a few years ago. I've gone so far as to look at replacing the engine and there does not appear to be an after market one. So now I think I need to look for a used motor or try and make another motor fit. Any ideas on where I might find a bearing plate, motor or how I might get the tap out would be appreciated. 1 Share this post Link to post Share on other sites
Ed Kennell 44,904 #2 Posted September 18, 2020 Any equipped machine shop should be able to burn it out. 2 Share this post Link to post Share on other sites
pfrederi 19,907 #3 Posted September 18, 2020 (edited) 19 minutes ago, Ed Kennell said: Any equipped machine shop should be able to burn it out. Ed: Question?? the end plate isn't steel it is some pot metal alloy can they still burn things out???? Edited September 18, 2020 by pfrederi Share this post Link to post Share on other sites
8ntruck 8,606 #4 Posted September 18, 2020 A plunge EDM machine will be able to burn the tap out of the hole. Years ago, I saw an article about converting an inexpensive engraver into a tap burner. Don't remember where, though. Probably Popular Mechanics or Popular Science. Share this post Link to post Share on other sites
953 nut 64,139 #5 Posted September 18, 2020 2 hours ago, Scott24 said: Any ideas on where I might find a bearing plate, Call Lincoln at A-Z Tractor, he will fix you up. https://a-ztractor.com/ 3 Share this post Link to post Share on other sites
Ed Kennell 44,904 #6 Posted September 19, 2020 3 hours ago, pfrederi said: Ed: Question?? the end plate isn't steel it is some pot metal alloy can they still burn things out???? Material should not be a problem Paul. The EDM can do some amazing pin point machining. 1 Share this post Link to post Share on other sites
WVHillbilly520H 10,378 #7 Posted September 19, 2020 @Ed Kennell ... Here is a "wire" EDM that I used to set-up program and run at the factory I learned machining in. VIDEO0045.mp4 1 Share this post Link to post Share on other sites
Scott24 2 #8 Posted September 19, 2020 1 hour ago, 953 nut said: Call Lincoln at A-Z Tractor, he will fix you up. https://a-ztractor.com/ Thanks 953 nut! They do show one in stock if the machine shop route doesn't work out for some reason. Thank you all for the feedback. Hopefully I can find a machine shop willing to take the time to help me out. 2 Share this post Link to post Share on other sites
JoeM 9,622 #9 Posted September 19, 2020 I know you have said you have tried to weld a nut to the tap and that surly is material that is small and hard to weld. I have in the past been able to slide metal down along the flutes of the a broken tap, tacked a flat washer to that area and then a nut on top. Of course you at dealing with a #10 size ish screw. Also a little heat during extraction will help also. 1 Share this post Link to post Share on other sites
Ed Kennell 44,904 #10 Posted September 19, 2020 Have you tried a tap extractor? https://www.ebay.com/i/264295132533?chn=ps&norover=1&mkevt=1&mkrid=711-213727-13078-0&mkcid=2&itemid=264295132533&targetid=4580290572086399&device=c&mktype=&googleloc=&poi=&campaignid=403204655&mkgroupid=1227055191472610&rlsatarget=pla-4580290572086399&abcId=9300377&merchantid=51291&msclkid=3eb030e518ed1ac89f2a6f831b45a386 Share this post Link to post Share on other sites
Scott24 2 #11 Posted September 19, 2020 JoeM thanks for that idea. I think the challenge will be in getting a piece of metal small enough to fit in the flute. Ed Kennel, I have tried a tap extractor although it may not have been a high quality extractor since I bent it some while trying to get the tap out. Thanks for the ideas. Share this post Link to post Share on other sites
JoeM 9,622 #12 Posted September 21, 2020 On 9/19/2020 at 1:00 PM, Scott24 said: metal small enough to fit in the flute Mig wire. Share this post Link to post Share on other sites
