Farmer Dave 0 #1 Posted September 14, 2020 I have a Wheel Horse 312–8, Garden Tractor Model No. 73429 and just replaced the battery three weeks ago with a new one. It started well after replacement, but now starting is difficult. Sometimes I just get a short clicking noise when attempting to start and the machine does not turn over. Sometimes after a few attempts, it starts up fine. Battery connections are all tight. Any ideas on what is wrong? Share this post Link to post Share on other sites
pfrederi 19,278 #2 Posted September 14, 2020 Tight doesn't always mean clean and corrosion free. Check the ground cable where it attaches to the frame. Check voltage with engine running you should get 13.5 to 14.5 maybe your charging system is bad killed first battery and isn't recharging this one. 3 Share this post Link to post Share on other sites
Lee1977 7,457 #3 Posted September 14, 2020 (edited) Check to see if the dash plate where the key switch is grounded. The 312's have just two 1/4" bolts grounding that panel, if the bolts and the panel is rusted you won't have a good ground. You also have a couple more bolted connection bwtween the switch and the normal negtive ground from the battery. I had that where it took 3 or 4 tried to get the engine to start. Edited September 14, 2020 by Lee1977 2 1 Share this post Link to post Share on other sites
Stormin 9,986 #4 Posted September 14, 2020 My guess, other that earths/grounds, is solenoid faulty. Share this post Link to post Share on other sites
peter lena 9,559 #5 Posted September 14, 2020 farmer dave, agree with above on the grounding issue , i also added a number of grounding points , at dash area and the engine to frame mounting point. used dielectric grease on all connections to enhance conductivity and reduce corrosion. also check out your fuses , for corrosion and condition. pete 1 Share this post Link to post Share on other sites
lynnmor 8,264 #6 Posted September 14, 2020 Yes, check the voltage with the engine running and also check if the battery is being drained when not in use. 1 Share this post Link to post Share on other sites
