Rp.wh 1,103 #1 Posted September 13, 2020 Alright I am not completely not with it when it come to wiring but I have replace voltage regulator, points, adjusted points, coil and condenser the on off switch was a toggle switch I hard wired it for the moment it was kinky looking and just to by pass it and I still have no spark should I just start from scratch and rewire the whole thing or any ideas would be helpful Share this post Link to post Share on other sites
WHNJ701 4,168 #2 Posted September 13, 2020 (edited) Follow the wiring diagram!! Check the flywheel key Check the flywheel magnet Check your ground Ngk spark plug Good coil wire Check your points, are they opening/gap, even if new file them Edited September 13, 2020 by jabelman 1 Share this post Link to post Share on other sites
ebinmaine 77,119 #3 Posted September 13, 2020 I'd answer that in two parts. 1. Anytime you think you need to rewire a whole tractor, you probably should. But!! 2. You REALLY should figure out the actual problem first Then, as stated above follow the original schematic to rewire. 1 2 Share this post Link to post Share on other sites
stevasaurus 23,568 #4 Posted September 13, 2020 Ryan...Eric's right...one thing at a time, otherwise you will have no idea what fixed it. There is not a lot of wires in a 702...touch both ends with a point meter...un-hook the battery. Check each wire at both ends...if you do not have a short, you have a high resistance open (a broken wire.). Fastest way to check wires for continuity. 3 1 Share this post Link to post Share on other sites
953 nut 63,986 #5 Posted September 13, 2020 Slow down and start addressing one component at a time. Is the wire from the ignition points in good condition and connected to the "-" side of your ignition coil along with the condenser? Is the coil wire to the spark plug in good condition? With the ignition points cover off rotate the flywheel in a clockwise direction until you see the points open, now slowly continue rotating until the points are open as far as they will go. The opening should measure 0.020". Rotate the flywheel until the points are closed. Remove the present wire from the ignition switch to coil and connect a small jumper wire from the battery "+" to the "+" on the coil. Open and close the points and see if you get a spark. If there is no spark remove the wire to the condenser and try again. Remove the jumper wire when finished. Let us know what you come up with. 3 1 Share this post Link to post Share on other sites
