TractorChild97 158 #326 Posted October 17, 2020 Just now, Oldskool said: It is Craftsman steering. The plastic bushing are pure junk. I have one in my race mower. I went thru that one and made all brass bushings for it with no issues to date. Thats a great idea actually. Iv rebuilt two with the plastic T bushings and they were good for alittle while but then again it was for mud mowers too. 1 Share this post Link to post Share on other sites
Oldskool 6,663 #327 Posted October 17, 2020 Just now, TractorChild97 said: Thats a great idea actually. Iv rebuilt two with the plastic T bushings and they were good for alittle while but then again it was for mud mowers too. Ever think about using the auger gear box off a snowblower for a steering box? Check one out 1 1 Share this post Link to post Share on other sites
ebinmaine 72,423 #328 Posted October 17, 2020 9 hours ago, Oldskool said: Ever think about using the auger gear box off a snowblower for a steering box? Check one out That's a neat idea Share this post Link to post Share on other sites
Oldskool 6,663 #329 Posted October 17, 2020 46 minutes ago, ebinmaine said: That's a neat idea Oh I'm full of them lol. Depending on the size of the steering wheel and length of pitman arm they work well. Also depending on which one you use mounting can be an issue, but some are easier then others 1 Share this post Link to post Share on other sites
ebinmaine 72,423 #330 Posted October 17, 2020 46 minutes ago, Oldskool said: Oh I'm full of them lol. Depending on the size of the steering wheel and length of pitman arm they work well. Also depending on which one you use mounting can be an issue, but some are easier then others PM sent Share this post Link to post Share on other sites
TractorChild97 158 #331 Posted October 17, 2020 13 hours ago, Oldskool said: Ever think about using the auger gear box off a snowblower for a steering box? Check one out Now thats something to think on! 1 Share this post Link to post Share on other sites
Oldskool 6,663 #332 Posted October 17, 2020 Dah horsey dont wanna run. It's being a P.I.T.A. Spark, air and starting fluid, wont fire. Gotta DIG deeper 1 Share this post Link to post Share on other sites
Achto 29,370 #333 Posted October 17, 2020 1 hour ago, Oldskool said: Dah horsey dont wanna run. It's being a P.I.T.A. Spark, air and starting fluid, wont fire. Gotta DIG deeper Check the fly wheel key. I have found that if I have every thing that I need on a Briggs but it won't run, chances are that the fly wheel key sheared some how. 3 Share this post Link to post Share on other sites
Oldskool 6,663 #334 Posted October 17, 2020 4 minutes ago, Achto said: Check the fly wheel key. I have found that if I have every thing that I need on a Briggs but it won't run, chances are that the fly wheel key sheared some how. That was the next thing I checked. That was the culprit. Purrs like a lion or um a HORSE 5 Share this post Link to post Share on other sites
Oldskool 6,663 #335 Posted October 18, 2020 http://www.youtube.com/shorts/GI8E18lmVLc 3 Share this post Link to post Share on other sites
Oldskool 6,663 #336 Posted October 18, 2020 It's still looking like a test drive video will be posted tomorrow. 2 1 Share this post Link to post Share on other sites
Oldskool 6,663 #337 Posted October 18, 2020 Asking for a friend. Other than saying DONT. If one was to cut open a propane tank what would be the safest way about doing it? Share this post Link to post Share on other sites
Tractorhead 9,209 #338 Posted October 18, 2020 drain it firstly completely, let it sat with open Valve in the Sun, that the Tank exceeds 10DegC fill it completely up with Water and close the Valve- firstly than begin the Cut. ( suggesting use an Accugrinder) That‘s definitively a mess, but the safest Way. organize a CO2bottle - a smaller bottle like for a fishtank Put a flow regulator on it, prespan it to 25l/ min connect it to lpg bottle and give it continusely a light preflow of CO2. CO2 is used to blow out the Water on the cut. No oxygene in the Tank while cutting - no booom. Cutted in the Past few Propane/ butane tanks that Way, But be aware it is a real Mess.. One Word - Please be extremely Carefully, one Mistake and - Boom.. I like to see you finalize you project. 2 2 Share this post Link to post Share on other sites
Oldskool 6,663 #339 Posted October 18, 2020 6 minutes ago, Tractorhead said: drain it firstly completely, let it sat with open Valve in the Sun, that the Tank exceeds 10DegC fill it completely up with Water and close the Valve- firstly than begin the Cut. ( suggesting use an Accugrinder) That‘s definitively a mess, but the safest Way. organize a CO2bottle - a smaller bottle like for a fishtank Put a flow regulator on it, prespan it to 25l/ min connect it to lpg bottle and give it continusely a light preflow of CO2. CO2 is used to blow out the Water on the cut. No oxygene in the Tank while cutting - no booom. Cutted in the Past few Propane/ butane tanks that Way, But be aware it is a real Mess.. One Word - Please be extremely Carefully, one Mistake and - Boom.. I like to see you finalize you project. Could I use engine exhaust? Does the propane permeate the tanks inner wall? Share this post Link to post Share on other sites
Oldskool 6,663 #340 Posted October 18, 2020 9 minutes ago, Tractorhead said: I like to see you finalize you project. I would too. I have several more builds in my head 2 1 Share this post Link to post Share on other sites
Tractorhead 9,209 #341 Posted October 18, 2020 48 minutes ago, Oldskool said: Could I use engine exhaust? Does the propane permeate the tanks inner wall? Not a good idea, because of flames out of exhaust. maybe rest oxygene in exhaust can be enough to ignite. grab a bottle co2 is the save Way. 1 Share this post Link to post Share on other sites
Tractorhead 9,209 #342 Posted October 18, 2020 (edited) As far as i remember you get a mig Welder, you can also use instead plain CO2 a Welding Gas for mig/tig Welding, but no acetylene or even oxygene... ....Or Kabooom..... Edit to answer your question Does the propane permeate the tanks inner wall no, but it contaminates the inner Wall. Another save solution is after fillup with Water stay it upright and drill holes in it. if Water dribbs out open the Valve and let it sat for a Day or two outside at a sunny Day to breath. Edited October 18, 2020 by Tractorhead 2 Share this post Link to post Share on other sites
Oldskool 6,663 #343 Posted October 18, 2020 @Tractorhead I need to cut 4 of them. Am I correct in thinking if it does blow up with the first bunch of sparks it's probably not gonna? 2 Share this post Link to post Share on other sites
ebinmaine 72,423 #344 Posted October 18, 2020 Our transfer station metal recycling facility requires that all propane tanks have a minimum of 2 holes in them. Propane is heavier than air. If the valve assembly can be removed and the tank left upside down it WILL drain on it's own. Right the tank. Fill with water. There is no propane left in a tank that's been air drained then water filled. Fun side note: I don't know what they do nowadays but they used to have an employee (who's retired) that would shoot the tank bottom with a .357. 2 holes..... 1 1 3 Share this post Link to post Share on other sites
Oldskool 6,663 #345 Posted October 18, 2020 19 minutes ago, ebinmaine said: Fun side note: I don't know what they do nowadays but they used to have an employee (who's retired) that would shoot the tank bottom with a .357. 2 holes..... Sounds like a fun job lol 1 Share this post Link to post Share on other sites
Oldskool 6,663 #346 Posted October 18, 2020 I would definitely pull the valve and rinse with water and soap. Probably gonna use up my welding gas to purge of oxygen. Not really sure how long I would have to run it in there after my first cut 1 Share this post Link to post Share on other sites
Tractorhead 9,209 #347 Posted October 18, 2020 25 minutes ago, ebinmaine said: Our transfer station metal recycling facility requires that all propane tanks have a minimum of 2 holes in them. Propane is heavier than air. If the valve assembly can be removed and the tank left upside down it WILL drain on it's own. Right the tank. Fill with water. There is no propane left in a tank that's been air drained then water filled. Fun side note: I don't know what they do nowadays but they used to have an employee (who's retired) that would shoot the tank bottom with a .357. 2 holes..... Did they search for another employee? 😎 2 Share this post Link to post Share on other sites
Tractorhead 9,209 #348 Posted October 18, 2020 (edited) As eric mentioned, after pulling the Valve and dry it upside down few hour‘s in the Sun there shall be no more gas Inside. i use the CO2 or Weldinggas on „ fresh Bottles“ after drainint until the Cut is that big, that the gas can freely blown. ( compared to a mig Welder) But i use mostly the „Waterversion“ for my own Safety. “reworked“ so few 5 kilo Propane bottles as a ministove. As long as the bottle is full, Gas outlet is higher than ignitionspeed, so only a Flame occurs outside but if the bottle goes empty on a warm day, and it is opened a bit longer when temp drops, air can be sucked into, that makes it dangerous. One spark and Kaboom if bottle is full of water, no air - gas ratio can occur, so no explosion can happen. Edited October 18, 2020 by Tractorhead Corrected 4 Share this post Link to post Share on other sites
Oldskool 6,663 #349 Posted October 18, 2020 I may have someone willing to do it. Just waiting on price from a blacksmith/machine shop. The wife would be ticked if I blew myself up lmao. But on the other hand these 4 tanks are getting cut one way or another 2 Share this post Link to post Share on other sites
Oldskool 6,663 #350 Posted October 18, 2020 Back on topic for a sec. No test drive today. The tank sealer hasnt cured yet. But it's already to go other than that 5 Share this post Link to post Share on other sites
