Dan87
Please help identify this blower, Found this blower for free
Dan87
Hey everyone!
Long time forum reader, first time poster! I just picked this blower attachment up last night for free! Thought it may fit one of my Wheel Horse tractors but once i got it home i was not so sure.
I have a 1986-87 - 212-6 and a 1970's C-100. Both have all the parts needed to attach a mower deck.
I have no idea how this one would attach to either, it may be missing parts? It does not have any model/serial numbers on it so i was having a hard time finding the manual that goes with it.
I also do not know if it was modified at any point, the man i got it from did not know what it came off and my best guess is it came with the house he said he moved into 1 year ago.
Thanks for the help!
oliver2-44
:text-welcomeconfetti:
The snow experts will be along shortly.
For a good reason I don't have any blower knowledge. don't need it living in central Texas.
Maybe I could use one as a big fan.
  • Haha 3
Stepney
Believe that belongs to a late 70's B series vertical shaft?
peter lena
DAN87 , the blower is essentially  a 36 x 42  single stage unit,  the difference being is that it was set up for a vertical engine , the main horizontal  SHORT  drive shaft and hook up will not work with the pto drive , found a picture , that shows the proper right hand pulley drive set up for your pto. not really a difficult change over , longer drive shaft , bearing mount swap ,and correct pulleys and belt tension frame , will get you going. you can probably search out parts on this site , from used units, let us know what you think , pete
Dan87
The brackets to attach to front are to wide for the c-100 and will not work.
My only hope is if it would then fit my Wheel horse 212-6 as i believe that one has a vertical shaft not the horizontal PTO drive?
this looks like the one i have from what you can see in image:
this is same model as one of my WH but blower not exactly the same but very similar.
Edited by Dan87
R. L. Addison
I have a D series that is very similar.
  • Similar Content
    • 87 416-8 horse
      By 87 416-8 horse
      I’m looking for wheel horse tractors for sale or for parts in the Eastern Nebraska or western Iowa area. Preferably 8 speed manuals. Pm me or comment with what you have. The worst I could say is it’s out of my price or distance range. Edit: engine is not important, it’s going to get a big diesel swap.
      Thanks,
      John
    • Jayzauto
      By Jayzauto
      Toro - WheelHorse SnowBlower fits “XT” Models.  Model 79483 Serial 240000164. In great shape, has high chute, wide kit installed and has belt.  Skids show little to no wear, so I’m guessing not used much.  SnowBlower only.  No mule drive or lifting hardware.
      $250/BRO
    • Duramax7man7
      By Duramax7man7
      Very Solid tractor! Starts right up and Runs and Cuts like a Champ!
      ONLY 419hrs
      FEATURES:
      Newer Agro Tires on Rear & Solid Front Turf Tires.
      Wheel Weights on rear.
      Fully Swapped Forward Swept axle and Steering off of 520h.
      New Tractor Supply Adjustable Seat.
      Exhaust Fully Restored. (Sandblasted, Outgassed and 2000deg High Temp Satin Exhaust Paint Coated.)
       I ran my 60" Deck on this tractor for over a year with no issues.
      Deck it solid top to bottom with no rot and newer blades. Belt and Pulley are good to go!
      She's just a little dusty and needs a cleaning. Can get a nice Seat a Tractor Supply.
      Asking >>>>> $1,099 OBO <<<<<<<
      (248) 943-8634 Text or Call.  God Bless.
    • Little Red Horse
      By Little Red Horse
      I am selling a 1970 Wheel Horse Electro 12. It is in *working condition*.
      It has AG tires and a mid-mount blade from wheel horse.
      It also has a front mounted generator that currently doesnt put out power. It has been in the barn quite a while, so it may be a corroded connection,  not sure. Although there's not too much that goes wrong with them.
      The tractor has been a great one for me. The last 6ish 7ish years that I've had it where I lived it brought the gravel back up my driveway for me every time it rained. In the last few months, it would run for 20-30min then die.
      I was moving at the time so just didn't have the time to look at it. And it seems I still don't. Where I am currently I don't have a place for it. I don't want it setting out and deteriorating. So here we are.
      Please contact me by text or email.
      Thanks for looking!
    • ohiofarmer
      By ohiofarmer
      i know that there is ebb and flow with market conditions, but I have been seeing bargain 520 and c-160 prices more common. I recently saw a c-160 like model on a place other than here that was close by, but i did not get a chance to see it as I was still on a medical tether getting care. i say c-i60 like model because it was a series of numbers like 4455 or somesuch .Tractor had the k series engine clearly a sixteen HP and came with a decent looking deck and pusher blade. i called my buddy Jay and told him for the $250 ask , he better hustle after it. i really do not know if he did.
        I also have been seeing 520s and such lower than I can remember as well as the D series..My theory is that people experiencing paycheck to paycheck living are increasing in number.
      You even are seeing a lot more older trucks like square bodies and especially big blocks than you did before. we used to see this a lot in new trucks when fuel prices hit records.
      i am not claiming expert status on this, but it seems to be trending this way one county next to indiana and 90 miles North of the Ohio River.
       Tell me what you are seeing out there and what you think.
           Edit:  Jay and I ran up to buy Bob Ellison's tractor in MI.  Bob was very nice to deal with and included his "last seat"   I got super lucky buying my first C-160 that did not start and another one shortly dropped in to keep it company. The tractor described above was listed for only two days and was gone
