Renrag 69 #1 Posted September 2, 2020 Ok mowingnight before last brakes went out when drive belt slipped off. Well further investigation i found collar on brake disc is cracked. I called sears and it was discontinued years ago, i have other brake discs, but they are splined and this one has a tapered moon key, so what is best option; pull the dana rear end and tare it apart and see if the shaft of a peerless would fit it, drive with no brakes, or dig till i find a old mower thats same. Whats y'all's thoughts ? Share this post Link to post Share on other sites
1995 520H+96+97 938 #2 Posted September 2, 2020 Go to E- bay find a used one. 2 Share this post Link to post Share on other sites
squonk 44,967 #3 Posted September 2, 2020 Try Stens or Jack's small engines 1 1 Share this post Link to post Share on other sites
Pullstart 68,557 #4 Posted September 2, 2020 9 hours ago, Renrag said: Whats y'all's thoughts ? 1 3 Share this post Link to post Share on other sites
oliver2-44 11,076 #5 Posted September 2, 2020 Can the collar be welded. Pictures would help see what you have. 1 Share this post Link to post Share on other sites
Stepney 2,357 #6 Posted September 3, 2020 I bet any bone yard would have the one.. I can picture it, worked on dozens of those in the younger race mower days. Share this post Link to post Share on other sites
bds1984 1,506 #7 Posted September 3, 2020 You have a Sears to call?!? Mine closed last November. Some pictures and model numbers would help us help you much quicker. There has to be a hundred of those transaxles in any junkyard. Share this post Link to post Share on other sites
Renrag 69 #8 Posted September 5, 2020 Sorry phones been screwed up, I'll get pics of collar in a bit, but i got numbers, and no i called sears, no help there. Share this post Link to post Share on other sites
Sam Pasch 450 #9 Posted September 7, 2020 If you have a flat yard I would just mow with no breaks. Worse comes to worst just jam it in reverse. Hey that rhymes. Share this post Link to post Share on other sites
