prondzy 3,889 #1 Posted August 31, 2020 does anyone have the dimensions for this spacer on an 875? Mine is missing and i have nothing to go by. Or possibly an extra one lying around??? Share this post Link to post Share on other sites
Achto 32,095 #2 Posted August 31, 2020 I believe that you could get away with some common washers there. It just needs to keep the pulley from rubbing on the bracket. 1 Share this post Link to post Share on other sites
prondzy 3,889 #3 Posted August 31, 2020 (edited) Dan of you look at the picture the bushing is shaped like a top hat and needs to go inside the bracket to keep proper spacing. I can turn one on the lathe if i could get some dimensions. Edited August 31, 2020 by prondzy Share this post Link to post Share on other sites
WHNJ701 4,173 #4 Posted August 31, 2020 Looks like a flange bushing, should be able to get one at your hardware store Share this post Link to post Share on other sites
Achto 32,095 #5 Posted August 31, 2020 I don't have any hydro's torn apart right now. Maybe @WHX24 has one in his parts pile. Share this post Link to post Share on other sites
WHX?? 57,395 #6 Posted August 31, 2020 (edited) Would it be the same as a '66 or 67 Mike? What's the part number? If it's the same I bet I have one. Looks like it is...# 80 bet there is one on the parts tractor. Will look tonite. There is a flanged reducer bushing that does the spacing, or helps, in the idler too if I remember right. From a 10/1277 IPL Edited August 31, 2020 by WHX24 1 Share this post Link to post Share on other sites
prondzy 3,889 #7 Posted August 31, 2020 5 hours ago, WHX24 said: Would it be the same as a '66 or 67 Mike? What's the part number? If it's the same I bet I have one. Looks like it is...# 80 bet there is one on the parts tractor. Will look tonite. There is a flanged reducer bushing that does the spacing, or helps, in the idler too if I remember right. From a 10/1277 IPL Yes #80 i just need some dimensions to get i close like i said i can probably just turn one on the lathe 1 Share this post Link to post Share on other sites
prondzy 3,889 #8 Posted August 31, 2020 Good news Jim, i had a lapse of memory and have a 1276 in the back fence i have a good spacer so no need to dig through your stuff! 1 Share this post Link to post Share on other sites
WHX?? 57,395 #9 Posted August 31, 2020 Good thing you told me was just headed down with a couple of 7/steens to check things out. Mighta poed me off woulda had to set my cocktail down to do it! Here's the real deal tho... 19 minutes ago, prondzy said: have a 1276 in the back fence i have a good spacer What else you got in that "fence" we oughta know about! 1 Share this post Link to post Share on other sites
prondzy 3,889 #10 Posted August 31, 2020 17 minutes ago, WHX24 said: Good thing you told me was just headed down with a couple of 7/steens to check things out. Mighta poed me off woulda had to set my cocktail down to do it! Here's the real deal tho... What else you got in that "fence" we oughta know about! Ahhh nuttin good 2 Share this post Link to post Share on other sites
WHX?? 57,395 #11 Posted August 31, 2020 1276 nuttin good!?!? Dan needs one to match his 1076.... 1 Share this post Link to post Share on other sites
gt14rider 1,242 #12 Posted September 1, 2020 Here's one off a gt14, 1 Share this post Link to post Share on other sites
pfrederi 20,870 #13 Posted September 1, 2020 The part number for an 875 spacer is 6134 (new number 100309 still available) For a GT-14 spacer 100431 (NLA) and for a Charger 7435 (NLA) Confused yet???? 1 1 Share this post Link to post Share on other sites
