Bill G 24 #1 Posted August 27, 2020 I would like to find a snowblower for my horse . I’m not sure what model or serial number will work with it if I find one . I have an “88” 312-8 Thank you Share this post Link to post Share on other sites
Ed Kennell 44,716 #2 Posted August 27, 2020 Bill, Garry @gwest_ca will probably be along to supply a list of implements that will fit your tractor. This post should be moved from electrical to the implements and attachments area. One of the moderators may move it for you. Just about any single stage blower (short or long chute) will work on your 312-8. There are three different mounting kits on some of the older blowers. Both the frame mount and the attach-a-matic will will work on the 312-8. The blade angle lever on some models may need to be modified to clear the foot rest or PTO. Be sure to get the push rod, flag, and angle lever when you buy a blower. With a manual lift tractor, you will probably need a lift assist spring kit. 2 Share this post Link to post Share on other sites
WHX?? 54,619 #3 Posted August 27, 2020 Attachment interchange list here for just about any . WH Interchange 1955-2000 (1).pdf 1 Share this post Link to post Share on other sites
Bill G 24 #4 Posted August 27, 2020 Ed Thank you . Also I didn’t even realize I posted in the electric form . I guess because my last post was about an electrical issue . I just post this new post there not realizing it . Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,987 #5 Posted August 27, 2020 Here are the models in the order they were produced and any will work. Study a parts list to make sure you get all the loose pieces. Front quick hitch introduced. Snowthrower rear frame has a 5/8" diameter round bar. 1973-74 model 6-6212 plus 6-9113 1974 model 6-6213 - (First model to include 8-0221 extensions without the front straight return - just a flat plate) 1975 model 6-6214 - (First model to include 8-0221 [103552 replaced by 93-1617 and 93-1617-01] side extensions with the front straight return. First model to have a cable spool on chute rotating crank) 1976 model 6-6215 - This one - 1976 model 66-42ST01 - and this one are likely identical. The model number format changed. 1977 model 76-42ST01 - This one 1978 model 86-42ST01 - and this one 1979 model 96-42ST01 - and this one plus 1980 may be all the same. They started using a different model number for each model year. 1980 model 06-42ST01 - (Last 42" model to use 4 grooved rollers for the chute) 1981-82 model 06-42ST02 - (First model to use plastic collar for the chute but was a retrofit for older models. Last model to use wheels) 1983 model 06-42ST03 - (First model to use skids) 1984-87 model 06-42ST04 - (Last model to use a 3/4" diameter driveshaft) 1987-89 model 06-42ST05 - (First model to use a 7/8" diameter driveshaft) 1990 model 06-42ST06 - (Last model to use a cable to turn the chute) 1991-93 model 06-42ST07 - (First model with tall chute retained by 3 individual grooved retainers) 1993-2001 model 79360 - (2001 and earlier will fit 2002-2007 with kit 105-1503) 2002-2007 model 79362 Garry 1 1 Share this post Link to post Share on other sites
Bill G 24 #6 Posted August 28, 2020 Awesome Thank you Gary Share this post Link to post Share on other sites
