sqrlgtr 4,155 #1 Posted August 24, 2020 Seems like I remember there was a good thread about the different transmissions that came in the different model wheel horses’.Im mainly interested in the 3/4and 6/8 speeds.Which ones that where limited slip and what models they came in etc.If someone could point me in the right direction or pass along some information I would appreciate it.Yes I tried the search function and couldn’t find what I wanted Share this post Link to post Share on other sites
ebinmaine 81,046 #2 Posted August 24, 2020 I'm not all that awesome at doing the searching myself. I can tell you that the limited-slip transmissions were used in the six speeds from 1967 to 1970. These were known as 10 pinion transmissions. Somebody else may pipe up and say there was another one or two. I'm not sure. 1 1 Share this post Link to post Share on other sites
WHX?? 58,324 #3 Posted August 24, 2020 This also should be in every horseman's back pocket. It gives the transmission usage for every year. @stevasaurus may have some kind of better spread sheet. He also knows which ones are LS and so forth. Also Lowell's document on what kit of his is needed for what tranny helps a bit too. TRANSMISSIONGUIDE.pdf Wheel_Horse_Products_Master_Model_List.pdf 2 1 Share this post Link to post Share on other sites
stevasaurus 23,861 #4 Posted August 24, 2020 Here is the manual you want to down load and study. The 1st pages list the horses and what transmissions they have, and the different sections describe the different transmissions. It's all there. If you have any questions after looking at this, please put them back in here. If I was going to type all you want to know, it would be this manual. Go to our Manuals Section on the Main Page...find Transmissions / Manual...it is all there. 3 1 Share this post Link to post Share on other sites
WHX?? 58,324 #5 Posted August 24, 2020 What manual Dino?? 1 1 Share this post Link to post Share on other sites
sqrlgtr 4,155 #6 Posted August 24, 2020 Thanks fellers I mustuv looked right over it. Thanks Again 2 Share this post Link to post Share on other sites
Greentored 3,221 #7 Posted August 25, 2020 @stevasaurus thank you sir! Have run across this list a few times while wandering the interwebs, educating myself with each purchase. This time I printed it off and it will be pinned in the stable for reference 1 1 Share this post Link to post Share on other sites
