Goofball65 13 #1 Posted August 22, 2020 ok, this is what i have WH model# T 856, Serial #193910 . all i know about it is suposibaly all orginal and rare. wondering if anybody can tell me more on ? i have and if parts are available for it ,. in process of restoring it and do to weather some of the parts are siezed." footpegs drivebelt pedel and pully assesmbly" and in process of tring to freeup I broke the dang things "stupid me" . will try to upload pics soon, just need to figure out how . Any info would be much appreciated. I have the pedal casting # 4239-B4 . also need all other parts that go with it, Share this post Link to post Share on other sites
Pollack Pete 2,273 #2 Posted August 22, 2020 I believe your tractor is a 1966 Model 856.Should be a Kohler 8 horse engine.Penetrating oil is your friend when working on tractors or anything else left out in the weather.Also a fair ammount of patients. 1 1 Share this post Link to post Share on other sites
Achto 32,095 #3 Posted August 22, 2020 This will help you find the part numbers that you will need https://www.wheelhorseforum.com/files/file/1843-tractor-1966-856-da-om-ipl-wiring-snpdf/ 1 Share this post Link to post Share on other sites
Goofball65 13 #4 Posted August 22, 2020 thanks guys and someone told me this was a 1963 ? has the 8horse Kohler and 3speed trany with clutch and that they only made this model 1 yr. "don't know" and yes PB Blaster is the bomb use it on just about everything . Share this post Link to post Share on other sites
rmaynard 17,424 #5 Posted August 22, 2020 (edited) PB Blaster works great on rusted, frozen parts. Don't use WD-40. It does not penetrate. Be patient. There are a lot of parts for that model that are interchangeable with other models. It's not rare. Most models early on were only made 1 year. 8 HP 5 Manual 6 1966. 857 is the same, just the 7 is from 1967. Edited August 22, 2020 by rmaynard 3 Share this post Link to post Share on other sites
Goofball65 13 #6 Posted August 22, 2020 oh yea the guy that told me that info is a JohnDere mech . 2 Share this post Link to post Share on other sites
stevasaurus 23,745 #8 Posted August 22, 2020 Actually...the 8 = engine horse power 8hp Kohler k-181s the 5= electric start the 6= 1966 Model # T856 The transmission is a Wheel Horse #5053 3 speed uni-drive. 3 forward and 1 reverse. These are not rare, but they are the favorite for many of us members. The 1965, 1966, and 1967s are considered Short Frame, Square Hoods. 4 1 Share this post Link to post Share on other sites
Tractorhead 9,217 #9 Posted August 23, 2020 17 hours ago, Goofball65 said: Firstly Happy Birthday @Goofball65, even i‘m late. when things be too heavy rusted on, i use few dribbs of Brakefluid and heat it up with a hotair gun, it penetrates heated better, than all other stuff i know because brakefluid can resist a lot of heat. But never use it on keeped painted surfaces, it‘s just for remove, When it‘s rusted over years. When this ain‘t helps, just a Torch or at Least a Burner can solve that. But be carefully on cast iron, here too much heat with a Burner can maybe damage more than it helps. Do this only outside of Rooms or well Ventilated, it is not a comfy solution and stinks heavy. 1 Share this post Link to post Share on other sites
sqrlgtr 3,263 #10 Posted August 23, 2020 18 hours ago, Goofball65 said: ok, this is what i have WH model# T 856, Serial #193910 . all i know about it is suposibaly all orginal and rare. wondering if anybody can tell me more on ? i have and if parts are available for it ,. in process of restoring it and do to weather some of the parts are siezed." footpegs drivebelt pedel and pully assesmbly" and in process of tring to freeup I broke the dang things "stupid me" . will try to upload pics soon, just need to figure out how . Any info would be much appreciated. I have the pedal casting # 4239-B4 . also need all other parts that go with it, Kroil is the best penetrating oil I've ever used.Good for cleaning rifle bores also. 1 1 Share this post Link to post Share on other sites
