dusted800 1 #1 Posted May 14, 2009 Ok, whats the secret to getting the pulley off the top of the shaft on a 42 inch rear discharge deck. I have a bearing that is starting to get noisey and have tried everything(heat, sprayed with penetrating oil, beat it with a hammer). I am also looking for a 36 inch side discharge deck for my C series tractor. I want to put a bag system on it and my dealer told me that I will have to find the 36 inch two blade deck in order for the deck to have enough lift to make the bag system work. thanx. wnk. Share this post Link to post Share on other sites
Sparky-(Admin) 23,147 #2 Posted May 14, 2009 I think what the dealer meant to say was a 37" side discharge deck and not a 36". There are more differances than just an inch between these decks. Now about the pulley. I just removed one of the outer pulleys from my 42"RD deck and to do it I had to remove the big nut on the top of the spindle, then remove the grease zerk (if you have one). I then put a piece of oak over the top of the spindle and gave it a few hits with my hammer. About 5 hits and the spindle came out the bottom and the pulley was free. I did all this with it still mounted in the deck but I suppose it could be done the same way with it supported in a vice. Good luck. Mike......... Share this post Link to post Share on other sites
can whlvr 994 #3 Posted May 14, 2009 I had one that i had to cut off with an angle grinder after i bent it with a gear puller,soaked it fore a while tried a very large pipe wrench,sledge hammer,heat,you name it i tried it but in the end just cut it off,replaced it for abouy 20 bucks from local bearing dealer. Share this post Link to post Share on other sites
zieg72 209 #4 Posted May 14, 2009 I made a spanner wrench to go over the shaft spindle and to fit in the (2) 1/4" holes. I held the spanner wrench on top and rotated the blade on the bottom. I destroyed 1 pulley the other was to. This method is great if you don't need to replace the bearings and just want to pull the spindle. Share this post Link to post Share on other sites
