Greentored
K301s/early Sundstrand combo, acts 'loaded'?
Greentored
Just a random topic for discussion and curiosity's sake. This one in particular my 1277 'lawn duty'. Engine is in a great state of tune (zero oil use since changed, maybe 20hrs) Trans is a C120 Sundstrand unit. That hydro unit really loads the engine when engaging the belt, especially cold (ambient). Fluid is 10w30. Tractor runs and mows great, but just seems like its 'working' a lot. Governor is adjusted correctly and does not lose rpm.
Is this just 'nature of the beast' with these? My bronco 14 is a touch on the tired side and does it too, but not like the 1277. Certainly wouldn't think that extra 2hp makes that much difference, or does it?
Whatcha think?
Mike'sHorseBarn
Following along to get an education :popcorn:
Ed Kennell
Some "experts" feel a Sundstrand requires about 3HP to move a tractor.          This leaves you with 9HP and 11HP to turn the blades.   That's 22% more available HP on the Bronco 14 for turning the blades.    :confusion-shrug:
pfrederi
My Sunstrands pull down the K301 and the Techy HH100 when you engage the drive but they recover ...Unless it is really cold then you have to be careful and slowly engage the drive.  All mine run ATF.
Stepney
How's your timing?
I used to run a B100 years ago that wouldn't pull a hill running a deck. Hydro and a 10 horse plus a 36"RD would kill it.. long story short points were way out.
Was still slow but much much better than it had been.
953 nut
:text-yeahthat:    I was thinking the same thing. Your ignition points set the ignition timing and if the timing is too late the engine will start fine and run OK without a load but power is reduced.
Greentored
Ya know, sitting here thinking- I never verified/adjusted the timing on this one- threw a set of points in when I got it this past spring, eyeballed em, and have been running the wheels off of it.
I do know governor adjustment and moving the springs around made a HUGE difference- that stopped the rpm loss....
Anyone ever try synthetic in these old Sundstrands? Does it help?
tom2p
the viscosity of the fluid can make a difference - but don't know how much
Greentored
Once again you fellas hit the nail on the head! I forgot the golden rule: KISS- "keep it simple, stupid".  Ignition timing checked with an ohm meter for points break- timing was dang near right on TDC instead of 20!
Now heres the odd part: at 20 degrees, the response and power are day and night, but it rattles like a SOB- like, scary. I decreased timing in increments to no avail, rolled it over til the points were at their widest spot, set with feelers to .020 and no rattle, but power is not like it was at meter verified 20.  TDC and 20 verified, so no flywheel slip issue. Any ideas?  Its on plain old 87 octane. Maybe start running 93 in these machines and pour the timing to em?
squonk
Maybe de-carbon the combustion chamber
prondzy
A hydro transmission will rob at least 30% of hp due to the pump turning,  cold fluid will only make a pump turn harder.
Greentored
@prondzy  that is exactly what it 'acts' like.  Think i'll yank the head and decarbon, lash the valves, put the timing light on it this go round and chalk it up to 'normal operation'.
  Will post up the results for others with questions to reference.
953 nut
:text-yeahthat:               Static timing should work but a timing light is the way to go.
ebinmaine
Me too..
