peter lena 9,559 #1 Posted August 15, 2020 recently been experimenting with 1/4" poly tubing , cut on length, to use on a cowl noise issue, you can probably pick up a few feet at your local h/w store , or big box store, https://www.amazon.com/s?k=1%2F4+in+poly+tubing&gclid=EAIaIQobChMIlurWwsid6wIVOv3jBx2nJw0nEAMYAiAAEgKvVfD_BwE&hvadid=267939633997&hvdev=c&hvlocphy=9003310&hvnetw=g&hvqmt=e&hvrand=10217430521638813034&hvtargid=kwd-447744249588&hydadcr=24657_9648987&tag=googhydr-20&ref=pd_sl_68kkwlzyvo_e , emphasis on twisting and bending it flat , do not kink it , so it sits on table with any bends or curls. i use a razor blade or exacto knife , to slice a straight line end to end on my measured piece , just slide it over the cowl mounting side and secure your hood , my noise is gone , with this easy improvement , just my own experience, pete 2 2 Share this post Link to post Share on other sites
squonk 44,878 #2 Posted August 15, 2020 I had a roll of seat trim. Sold all I had for the same purpose. 4 Share this post Link to post Share on other sites
peter lena 9,559 #3 Posted August 15, 2020 squonk, i was trying to find that trim edge, when i came up with a why not try that ? i only use it on the straight flat area , eliminating the curve angle area. keep on tweakin , pete 1 Share this post Link to post Share on other sites
JAinVA 4,638 #4 Posted August 15, 2020 (edited) You can also use car door edge protector. It comes ready to apply,is inexpensive and comes in a variety of colors.The front edge of the black hood has a red door guard section applied.It is a little faded from the sun but still does the job. Edited August 15, 2020 by JAinVA 3 1 1 Share this post Link to post Share on other sites
Daddy Don 911 #5 Posted August 15, 2020 I use this on all my works great. 3 Share this post Link to post Share on other sites
Skwerl58 770 #6 Posted August 15, 2020 I have used short pieces of fuel line that I had laying around to prevent the rattles and squeaks. I also have used u channel for this as well and on metal edges to prevent getting cut by the exposed sharp corners and edges. 3 Share this post Link to post Share on other sites
JAinVA 4,638 #7 Posted August 15, 2020 Best use for old fuel lines there is .The reinforcing strands add strength.Thinking out side the box and recycling with what's on hand. 3 Share this post Link to post Share on other sites
Redneckdavis 308 #8 Posted August 15, 2020 (edited) Or go for chrome. At local auto parts. Door trim? Edited August 15, 2020 by Redneckdavis 3 Share this post Link to post Share on other sites
echris 1,425 #9 Posted August 25, 2020 I just did this a few weeks back on my 310-8. The throttle lever wouldn't hit 100% because the hood was sitting too low at the back. New 3/8" fuel line and I added a little slice of extra 3/8" fuel line to the center of the tube to give the hood a bit more height. Didn't glue anything, it sticks nice even with the extra piece inside. 1 Share this post Link to post Share on other sites
SylvanLakeWH 29,880 #10 Posted August 27, 2020 Great idea! Maybe I will be able to hear the engine on the WHrat WHrecker if I do this...! 1 Share this post Link to post Share on other sites
AMC RULES 37,250 #11 Posted August 27, 2020 I wouldn't change a thing on that black hooded beast! 1 Share this post Link to post Share on other sites
D_Mac 9,330 #12 Posted August 28, 2020 I use door edge guard for a lot of things. I buy it in a big roll. When I had my bike I wrapped both fenders, the gas tank, and the edge of the windshield with it. Looked great and lasted forever. If you look close on the picture you can see it. 1 1 Share this post Link to post Share on other sites
