T1000 0 #1 Posted August 12, 2020 Hey i have had this tractor growing up and inherited my father's 312 8. The mower deck used to throw grass well and now its just dropping it and leaving a nice trail of clipping as I go along. Is it just blades that needs replacing or maybe something else? Share this post Link to post Share on other sites
Pullstart 68,981 #2 Posted August 12, 2020 RD decks aren’t known too well for tossing clippings like a SD deck can. How much grass are you cutting inches wise, I recall if the grass grew too long it would pile up a nice windrow in the center. We like pics by the way 1 Share this post Link to post Share on other sites
8ntruck 8,626 #3 Posted August 12, 2020 Welcome to the forum. Bunch of good folks here. I switched from a SD deck last year to a RD deck. The RD deck works great in combination with a tow behind sweeper. However, I've noticed that when cutting longer grass, the RD deck does tend to leave windrows. I'll agree that a SD deck spreads trimmings better than the RD deck. 1 1 Share this post Link to post Share on other sites
Tractorhead 9,216 #4 Posted August 12, 2020 Hi and to a pic of the result can give more info’s about your problem. Maybe it’s just the blades they need resharpening. Share this post Link to post Share on other sites
tom2p 2,394 #5 Posted August 12, 2020 (edited) keep blades sharp - rpm up but as others in prev posts mentioned - RD deck typically will not spread grass clippings as well as a similarly sized SD deck I currently use SD deck more often than RD - but cut for decades with a 704 and 312-8 with RD decks compared to SD deck - gotta keep the RD deck slightly higher (cut less grass) to minimize grass clippings from clumping behind the deck also - keep the front of the deck slightly higher than the rear can also add a deflector to the rear portion of the deck (as shown below) Edited August 12, 2020 by tom2p 1 Share this post Link to post Share on other sites
Stepney 2,357 #6 Posted August 12, 2020 14 minutes ago, tom2p said: also - keep the front of the deck slightly higher than the rear The front higher than the rear? I have a 42" that is quite miserable to use. Set the front lower, by the book, a dozen ways. Never helped.. never thought to try against the book.. any idea on the reasoning? Share this post Link to post Share on other sites
T1000 0 #7 Posted August 13, 2020 As soon as my step pulley comes in I will post some picks. The pulley snapped on me and the grass has gotten quite tall since then, so it will look horrible I'm sure. As far as the blades go they are nice and sharp and balanced as well. I've been pondering converting it into a SD. Any thoughts to this? I'm not quite sure how the aerodynamics of the deck would play out Share this post Link to post Share on other sites
Tuneup 1,452 #8 Posted August 13, 2020 My deck's going to look just like that after its cosmetic go-over this winter. Thanks, for the example! Share this post Link to post Share on other sites
lynnmor 8,645 #9 Posted August 13, 2020 The “book” does say to run the front higher, quite the opposite of nearly all other decks. There are several versions of the RD decks, I didn’t look up yours. Some have no baffles, some partial and some are fully baffled. I have the no baffled version and it is horrible if grass is high so I need to pull the sweeper to make it presentable, therefore I only use it for fall cleanup. Always mow at full throttle. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,015 #10 Posted August 13, 2020 Using the correct pto pulley? Garry 1 Share this post Link to post Share on other sites
clueless 3,348 #11 Posted August 13, 2020 Not sure what you mean by throwing grass, the rear discharge decks were not designed to throw clippings. 1 Share this post Link to post Share on other sites
Tach-a-matic 357 #12 Posted August 23, 2020 The book also does not say to remove the rear hub caps when using a RD deck, but its probably a good idea 1 Share this post Link to post Share on other sites
953 nut 64,332 #13 Posted August 23, 2020 On 8/12/2020 at 5:51 PM, T1000 said: The mower deck used to throw grass well and now its just dropping it and leaving a nice trail of clipping as I go along. Is the deck a side discharge deck? If a side discharge deck isn't throwing clippings it could be the RPMs of the engine are not high enough or as Garry said, the wrong pulley on the PTO being used. If your deck is a rear discharge like @tom2p pictured then it is doing what it was designed to do. Share this post Link to post Share on other sites
953 nut 64,332 #14 Posted August 23, 2020 1 hour ago, Tach-a-matic said: book also does not say to remove the rear hub caps when using a RD deck, but its probably a good idea Some duct tape over the slots on the rims will cure that. Share this post Link to post Share on other sites
