The Tuul Crib 7,354 #1 Posted August 10, 2020 Get the the gear drive together yesterday and I'm having a little issue. I torqued the bolts to proper spec numbers and when I go to turn the gear it turns rather hard. Took it back apart make sure the needle bearings were not in the way, everything is fine. It just feels like it's dragging not quite grinding but as though it's riding metal to metal. any thoughts?; IMG_8363.MOV Share this post Link to post Share on other sites
daveoman1966 3,882 #2 Posted August 11, 2020 If the gear would turn easily by hand, I'd expect something wrong. Know that you have all refinished (and some new parts?) and that during the initial 'break-in' period I'd not be surprised that the gear would be tight or hard to turn by hand. If you've followed torque specs, applied a generous amount of pre-lube (breakin oil), and followed the manual, your fear is probably unwarranted. 2 Share this post Link to post Share on other sites
The Tuul Crib 7,354 #3 Posted August 11, 2020 3 hours ago, daveoman1966 said: If the gear would turn easily by hand, I'd expect something wrong. Know that you have all refinished (and some new parts?) and that during the initial 'break-in' period I'd not be surprised that the gear would be tight or hard to turn by hand. If you've followed torque specs, applied a generous amount of pre-lube (breakin oil), and followed the manual, your fear is probably unwarranted. Really no new parts in this area. You mention "breakin in oil" what type of oil should be used? Share this post Link to post Share on other sites
953 nut 65,258 #4 Posted August 11, 2020 It has been several years since I did my Hydro-gear but I don't remember it being easy to turn. The tolerances in a hydraulic motor are very close.Was it easy to turn before you took it apart?? Share this post Link to post Share on other sites
Pullstart 69,690 #5 Posted August 11, 2020 Not knowing the innards of these, I was thinking the same while watching the video. I’d imagine they aren’t supposed to spin easy. Just think how they lock up when you try to push them! Share this post Link to post Share on other sites
The Tuul Crib 7,354 #6 Posted August 11, 2020 Im fine with all that and if thats normal great.The thing is no new parts. The reason l took it all apart was to clean it up thoroughly. The parking break pawl was chewed up and l wanted to make sure there was no metal shards left inside. Seems it turned a little easier before. I just wish there was anything other than the repair manuals that l have for these internal parts installation. Share this post Link to post Share on other sites
gt14rider 1,158 #7 Posted August 11, 2020 Just checked out my pump gear and can turn with two fingers, but there's some resistance. Will the shaft move smoothly with end cap off, when putting on end cap does it go on smoothly, maybe tap on the two pins or tap on end cap with a soft dead blow hammer while torquing down, also when torquing bolts, tighten in two steps, tapping with hammer and checking gear as you tighten. Also assembling lube for bearings and gears, talked to LJ and said that thay use blue loc tight between pump halfs. 20200811_091005.mp4 Share this post Link to post Share on other sites
The Tuul Crib 7,354 #8 Posted August 11, 2020 44 minutes ago, gt14rider said: Just checked out my pump gear and can turn with two fingers, but there's some resistance. Will the shaft move smoothly with end cap off, when putting on end cap does it go on smoothly, maybe tap on the two pins or tap on end cap with a soft dead blow hammer while torquing down, also when torquing bolts, tighten in two steps, tapping with hammer and checking gear as you tighten. Also assembling lube for bearings and gears, talked to LJ and said that thay use blue loc tight between pump halfs. 20200811_091005.mp4 Yes before I put the cap on you can turn the shaft freely. I put the cap on and tap it in place and the shop still turns freely. Only until you talk them down is when it tightens up. I noticed you put some red colored lube in place. Is that trans fluid? Share this post Link to post Share on other sites
gt14rider 1,158 #9 Posted August 11, 2020 Cam shaft lube, put some on bearings, gears. Permatex make some, or manny others. Share this post Link to post Share on other sites
gt14rider 1,158 #10 Posted August 11, 2020 Use that lube though out intire pump, squash plate ,brass slippers. When all else fails get a bigger freaken hammer Share this post Link to post Share on other sites
lynnmor 8,744 #11 Posted August 11, 2020 Am I seeing cracks in both halves? Share this post Link to post Share on other sites
The Tuul Crib 7,354 #12 Posted August 11, 2020 1 hour ago, gt14rider said: Use that lube though out intire pump, squash plate ,brass slippers. When all else fails get a bigger freaken hammer Here's a question for you I know that automatic transmission fluid is formulated for friction is that correct? If so then maybe I should not be using it to put this together. I thought it is made for surfaces to grab hold of one another as a spin to gain momentum. Share this post Link to post Share on other sites
daveoman1966 3,882 #13 Posted August 11, 2020 Inasmuch as there was no liquid or gasket sealant between the two sides of the Hydro Gear (not the pump), I don't know that it is a good idea to use any sort of sealant. When torqued down, that sealant will 'squeeze' into the circulating fluid and work its way thru the entire system...contaminating the fluid. The sealant won't dissolve and just 'go away'. 1 Share this post Link to post Share on other sites
The Tuul Crib 7,354 #14 Posted August 11, 2020 And l wonder how well the ultra slick mixes with the ATF? Share this post Link to post Share on other sites
gt14rider 1,158 #15 Posted August 11, 2020 The lock tight was advice I got from LJ or tim at LJ power, thought maybe thay put a couple of these together before and knew what they're doing. Share this post Link to post Share on other sites
daveoman1966 3,882 #16 Posted August 11, 2020 (edited) In 30+ years and a dozen or more of these that I have torn down and/or rebuilt, never did I find one that had any sort of sealant or gasket as in the pic that I posted. These are match-machined faces and held by EIGHT bolts. It takes 8 bolts torqued in sequence to ensure perfect fit precluding the need of a gasket or sealant. To each his own though. Edited August 12, 2020 by daveoman1966 1 Share this post Link to post Share on other sites
pfrederi 20,271 #17 Posted August 11, 2020 (edited) OK so i have at least 5 hydro gears. I have opened the pump end and resurfaced the slippers and the piston block. etc. Some had been a bit chewed up. Flushed out the gear motor but never opened them. they all work just fine. Really have never seen a need to open up the motor as there is really nothing you can do to "fix" it . They are pretty simple so it is easy to flush them out.. They are also steel so much less likely to have been damaged by dirt, metal bits etal. as the pump parts. After following this thread guess i will continue to leave them alone. (I think there is a reason why the manuals do not go into them.... Edited August 11, 2020 by pfrederi Share this post Link to post Share on other sites
The Tuul Crib 7,354 #18 Posted August 11, 2020 (edited) Well then l guess ill try and figure it out on my own. Thanx anyway. l'm not getting the support needed to help me thru this . Some good, others not so much. Edited August 12, 2020 by The Tuul Crib Share this post Link to post Share on other sites
pfrederi 20,271 #19 Posted August 12, 2020 1 hour ago, The Tuul Crib said: Well then l guess ill try and figure it out on my own. Thanx anyway. l'm not getting the support needed to help me thru this . Some good, others not so much. I think the problem is not many people have opened up the gear motor part so there is not a lot of expertise out there to help. 1 Share this post Link to post Share on other sites
The Tuul Crib 7,354 #20 Posted August 12, 2020 (edited) Why is that a problem ? Fact is this site is supposed to be for support and help. As l said l can figure this out myself. Edited August 12, 2020 by The Tuul Crib Share this post Link to post Share on other sites
squonk 46,115 #21 Posted August 12, 2020 If any sealant is supposed to be between the halves. I would think it would be this :https://www.henkel-adhesives.com/us/en/product/flexible-sealants/loctite_518.html Share this post Link to post Share on other sites
953 nut 65,258 #22 Posted August 12, 2020 11 hours ago, The Tuul Crib said: l'm not getting the support needed to help me thru this There are very few subject matter experts out there on half century old obscure technology but we all try to help and learn from each other. 1 Share this post Link to post Share on other sites
The Tuul Crib 7,354 #23 Posted August 16, 2020 Just got it back together and mounted back on the frame. 1 1 Share this post Link to post Share on other sites
Stormin 9,987 #24 Posted August 16, 2020 What was the problem with the bolts when tightened locking things up.? Share this post Link to post Share on other sites
The Tuul Crib 7,354 #25 Posted August 16, 2020 11 minutes ago, Stormin said: What was the problem with the bolts when tightened locking things up.? Not sure before I put it together the last time I added some of the permatex ultra slick. I didn't torque on them as much as before. Maybe within 3 or 4 pounds less .I'm thinking once I get the fluid in and moving it should be OK. 2 Share this post Link to post Share on other sites
