vmen84 61 #1 Posted August 9, 2020 To start off I was mowing the backyard and I guess I didn't see one of the dogs toys that I apparently didn't see which was cloth I realize this after I got halfway through mowing then by that point one of the belts had burnt up Believe is the drive belt I have a few questions. First what size belt does it be 100 wheel horse 1974 take second are there any good videos on how to replace those belts are there any videos that I can watch that show me how to do this step-by-step? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,454 #2 Posted August 10, 2020 Belts are specific to the mower deck - not the tractor. Width of cut and side or rear discharge often makes a difference. Guessing you have a 36" width of cut. May not be the models you have but the belts will be the same. Click on the pictures for the belts Garry Share this post Link to post Share on other sites
vmen84 61 #3 Posted August 10, 2020 ok thanks I appreciate it Share this post Link to post Share on other sites
vmen84 61 #4 Posted August 10, 2020 So it looks like this I am new to this so what size belt would that be for the 36 inch mower deck and I'm assuming it's only belt i'll have to replace because I know there's belts underneath the deck as well but I'm not sure if those are bad now Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,454 #5 Posted August 10, 2020 Sorry thought it was a mower belt you lost. This is for the tractor drive belt to the hydro transmission. The sizes listed are for the original belt. If you get an after-market replacement it will be even inches in length and get one designed to bend backwards over a flat idler. 5/8" x 84" should work. Garry Share this post Link to post Share on other sites
vmen84 61 #6 Posted August 10, 2020 Do you know if there's any videos on how to change the belt? Share this post Link to post Share on other sites
vmen84 61 #7 Posted August 10, 2020 So I called the local mower shop and they said they couldn't even find the model in the system which would be accurate I know what I'm looking for with the transmission drive but is there a certain belt/serial number or model number that I need? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,454 #8 Posted August 10, 2020 Tractor drive belt # 7478 replaces # 4535 - (HB/5L x 84.22" or 5/8" x 84.22") from belt chart and appears to be correct. 1974 B-100 Auto model 1-0510 Garry Share this post Link to post Share on other sites
vmen84 61 #9 Posted August 24, 2020 Good evening so quick update I got the belt that I need but because of my lack of knowledge I got the mower in the shed previously and I thought to myself yes this is a win when I went to go change the belt today and because of my lack of knowledge regarding anything mechanical or mower wise I didn't realize he wouldn't back up without a belt so I waited till this evening to go do this that's not gonna work because one my shed is not that big two I'm not flexible enough to get all the way down so it looks like I'm going back to the drawing board So I need to figure out how to get the mower out of the shed to change the belt via a YouTube instructional video until then I can't really do anything so any suggestions would be welcomed Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,454 #10 Posted August 24, 2020 This operator manual should help. It is in 2 parts and the 2nd part covers moving the tractor and replacing the belt. Garry 1 Share this post Link to post Share on other sites
