pfrederi
Reasonable Source for lift Trunnions
1988_wheelhorse312
Okay so this is my fix. Drilled the hold in the rockshaft are closest to the pivot out to a half in. I installed a 2200lb working load drop forged 1/2 eyebolt with the shaft cut short enough to fit. Several washers, and some grease. I then JB welded 2 3/8 washers into the eye on the bolt to act as a bushing to keep the adjustment eyebolt centered. Then I added 3 fender washers with the side trimmed out to fit around the shoulder on the eyebolt. Lastly I bolted it on with a nylon lock washer so the bolt can rotate freely but there is no side to side play, and then locked it down with a second bolt. Works really good. The 90 degree side pull on that eye bolt is 25% of its  2200lb working load, making it 550ish lbs of side pull. The lift its self would probably break before the eyebolt. I created it for others to follow along who have minimal tool in their shop but need to solve this issue. Only real fail point is the 2 washers JB welded in to serve as a bushing. And if those fail, ill just take it to a shop and have it all welded together. In the mean time Happy Horsing and Happy Thanksgiving!
