peter lena 10,047 #126 Posted May 28, 2022 @JoeM fellow C-85 owner , bought mine new in 82 , like your swap over , went 12 hp mag , a few years back , still my favorite horse. lots of experiments to eliminate nagging problems , very solid and reliable . mechanical function detailing , and electrical , upgrade , makes it run without effort . pete 2 Share this post Link to post Share on other sites
Dan.gerous 2,696 #127 Posted May 28, 2022 1 hour ago, JoeM said: Two on one machine maybe? Custom one to run the trans the other for the deck etc.? Twin engine black hood.....now I'm a think n! Lol, that could work, sound like a beehive if you didn't get revs the same! 1 Share this post Link to post Share on other sites
Dan.gerous 2,696 #128 Posted May 28, 2022 Will get one fired up, see what I can do with them. That's my budget blown until I get them away again 🙄 1 Share this post Link to post Share on other sites
JoeM 10,252 #129 Posted May 28, 2022 Dan, I can see it now. lengthen the frame and hood a foot and have one bad ass looking machine. 1 Share this post Link to post Share on other sites
Dan.gerous 2,696 #130 Posted May 28, 2022 41 minutes ago, JoeM said: Dan, I can see it now. lengthen the frame and hood a foot and have one bad ass looking machine. They are quite short, might get them both in as it is, do away with battery box... Share this post Link to post Share on other sites
JoeM 10,252 #131 Posted May 28, 2022 2 minutes ago, Dan.gerous said: might get them both in as it is, do away with battery box... got ya thinking huh! 1 Share this post Link to post Share on other sites
Dan.gerous 2,696 #132 Posted May 28, 2022 31 minutes ago, JoeM said: got ya thinking huh! I did sail on a ship that had two inline 6 cylinder engines that sat side by side and shared a single output shaft. It was technically one engine, and wasn't a huge success! You could have both engines running the pto, but getting the revs correct would be a nightmare. Or maybe with the auto box and a separate pump on other engine for FEL..... No!!!!! I should get sensible and work out how to get the 10hp by swapping these or something. Have found a couple of cement mixers with broken engines, could refurbish and sell. All a lot of extra effort though. 1 Share this post Link to post Share on other sites
Dan.gerous 2,696 #133 Posted May 28, 2022 Some pics. Found an id number as well. Lovely night so painting sheds with bbq in background - this place will be immaculate by the time we leave. I hope new tenants look after the place. Share this post Link to post Share on other sites
Dan.gerous 2,696 #134 Posted May 28, 2022 Ha, would you believe they are Robin engines! 4.8hp - baby brothers of the ones wheelhorse used on the diesels. 1 Share this post Link to post Share on other sites
Dan.gerous 2,696 #135 Posted May 29, 2022 I wonder if 4 8hp would be too gutless, half tempted to just install one. Selling this stuff is a nightmare with scammers and people that get in contact then disappear. I guess it would be about the same as a 7/8hp petrol with the torque available. Share this post Link to post Share on other sites
JoeM 10,252 #136 Posted May 29, 2022 I like the idea. Just looking could connect a 90 on to the exhaust to turn it. If I was a bit closer I would take one if you threw in a beer or two! 1 Share this post Link to post Share on other sites
ebinmaine 80,651 #137 Posted May 29, 2022 I'm not very familiar with diesel engines in particular for garden tractor usage. I can say that 8 horse is more than enough for a manual transmission Horse as long as you don't intend to use it for ground engagement mechanisms or thick heavy mowing. It would certainly be capable of moving the machine and a fair load be pulled. 1 1 Share this post Link to post Share on other sites
Rob J. 1,944 #138 Posted May 29, 2022 Thought about doing an Lombardini swap. The one I found is rated at 11hp I believe. I’d have to do some serious fab work to fit it though. Not sure I’m the guy but sure would love to see it in a Horse though. IMG_5832.MOV 3 Share this post Link to post Share on other sites
Dan.gerous 2,696 #139 Posted May 29, 2022 8 hours ago, JoeM said: I like the idea. Just looking could connect a 90 on to the exhaust to turn it. If I was a bit closer I would take one if you threw in a beer or two! Your too late, just sold one to a guy in the Orkney Islands Can still do the beer though. 3 Share this post Link to post Share on other sites
Dan.gerous 2,696 #140 Posted May 29, 2022 (edited) 19 hours ago, Rob J. said: Thought about doing an Lombardini swap. The one I found is rated at 11hp I believe. I’d have to do some serious fab work to fit it though. Not sure I’m the guy but sure would love to see it in a Horse though. IMG_5832.MOV I guess it depends on the height as to how much fabrication is needed. Just looking at a deutz F1L 210d, it has a really nice cooling system and lots of spinning bits on the outside - but it's 10cm higher than the Yanmar. Would need a scoop or something on the hood to make it look right. Edited May 30, 2022 by Dan.gerous 1 Share this post Link to post Share on other sites
Dan.gerous 2,696 #141 Posted May 29, 2022 8 hours ago, ebinmaine said: I'm not very familiar with diesel engines in particular for garden tractor usage. I can say that 8 horse is more than enough for a manual transmission Horse as long as you don't intend to use it for ground engagement mechanisms or thick heavy mowing. It would certainly be capable of moving the machine and a fair load be pulled. The 8hp equivalent would be mostly fine for tinkering about, but with luck I can shift the Robins for a small profit and work my way up to something bigger.... 2 Share this post Link to post Share on other sites
Dan.gerous 2,696 #142 Posted May 29, 2022 (edited) Here is the Deutz F1L 210 D - it's 13hp. The cooling fan is belt driven rather than off the crank. I think it also has a half speed pto for hydraulics. Tapered shaft and unknown service history, but I might just take the gamble - will study the manual in the morning and decide then. Dimensions are a bit big, but I think he has included the generator frame it sits on. Have found an online manual for correct dimensions, but it won't open on phone. This is also in Orkney, so could drop one engine off and pick another one up when the ship gets in on Thursday night. Edited May 30, 2022 by Dan.gerous 3 Share this post Link to post Share on other sites
Dan.gerous 2,696 #143 Posted May 31, 2022 Was dropping a hire trailer off yesterday in town, around the back of the hire place the yard is full of every machine known to man. Anyway, realised I hadn't swept out the trailer so went for a wander to find the guys that do the maintenance. One guy was pressure washing a digger and he kindly pointed out a broom nearby, so I walked over to get it. The broom was leaning on the wall near his pressure washer, which was a diesel Yanmar L100. Oh my god what a sexy machine! it was rumbling away at half throttle and sounded fantastic. Not as noisy as I thought it would be, but it is a huge unit - makes the Robins look like toys. In that moment I decided that's what we are getting, it is just such a quality little unit and worth holding out for. So trailer got swept out (I hate returning things dirty - also greased everything for them) and I got a close up look at one of Yanmars beasts in action - a successful outing in my book! 2 Share this post Link to post Share on other sites
Dan.gerous 2,696 #144 Posted June 2, 2022 One of the little Robin engines on its way to a new owner in Orkney. Best way to stop it moving about was by using a seat belt 2 1 Share this post Link to post Share on other sites
Maxwell-8 4,371 #145 Posted June 2, 2022 2 hours ago, Dan.gerous said: One of the little Robin engines on its way to a new owner in Orkney. Best way to stop it moving about was by using a seat belt That wasn't a option when I picked up my lombardini, that thing was nice and greasy, weighing around 180lbs. That would have left a nice mark on those leather seats haha. I have a 14hp, the engine is tall, I need a 4" hood lift to have enough room for the diesel monster 1 2 Share this post Link to post Share on other sites
Dan.gerous 2,696 #146 Posted June 2, 2022 2 hours ago, Maxwell-8 said: That wasn't a option when I picked up my lombardini, that thing was nice and greasy, weighing around 180lbs. That would have left a nice mark on those leather seats haha. I have a 14hp, the engine is tall, I need a 4" hood lift to have enough room for the diesel monster That is a beast! I notice most of the diesels are tall engines compared to the petrol counterparts - just to make a suitable candidate harder to find! Using the height modification to add a winch is a great idea. 1 Share this post Link to post Share on other sites
Dan.gerous 2,696 #147 Posted June 2, 2022 Luckily this engine is brand new, doesnt even have oil in it other than the residue from whatever tests the factory do. I have a guy who is going to fabricate a 1" keyway adapter to my other one, just in case I decide to use it. 1 Share this post Link to post Share on other sites
Dan.gerous 2,696 #148 Posted June 2, 2022 9 hours ago, Maxwell-8 said: That wasn't a option when I picked up my lombardini, that thing was nice and greasy, weighing around 180lbs. That would have left a nice mark on those leather seats haha. I have a 14hp, the engine is tall, I need a 4" hood lift to have enough room for the diesel monster Does taking the tank off help? I notice most of the conversions seem to use the engines tank rather than the Wheelhorses original one under the seat (for those that have it). That Duetz I have been umming and ahhing over has the same problem, its just so tall. Share this post Link to post Share on other sites
Maxwell-8 4,371 #149 Posted June 2, 2022 (edited) 9 hours ago, Dan.gerous said: That is a beast! I notice most of the diesels are tall engines compared to the petrol counterparts - just to make a suitable candidate harder to find! Using the height modification to add a winch is a great idea. thanks, Diesel have beefier parts, often longer compression strokes add the OHV design that is strait up, not at an angle like honda and predator engines. and the decomp, injector, etc Just to give you an idea, here is how my engine is build: 2 hours ago, Dan.gerous said: Does taking the tank off help? I notice most of the conversions seem to use the engines tank rather than the Wheelhorses original one under the seat (for those that have it). That Duetz I have been umming and ahhing over has the same problem, its just so tall. Taking off the tank doesn't really help, although I will have to relocate mine to the outside of the hood. Using the original tank is much easier, gravity fed. Don't know how they will behave when they have to get the diesel from that far, or what a extra diesel pump will do. I guess we just play on safe. 1 gallon of diesel will bring you a lot of run time. Edited June 2, 2022 by Maxwell-8 1 Share this post Link to post Share on other sites
ebinmaine 80,651 #150 Posted June 2, 2022 Do these little diesels need to keep a constant prime like our big trucks do? Or can they just pull up the fuel through a formerly empty line like a gas engine? 1 Share this post Link to post Share on other sites
