Ian ORCHARD 1 #1 Posted August 4, 2020 I've got a Wheel Horse Raider 10 that runs great on full throttle, no petrol smells at all from exhaust, until 10-15 minute mark and nice and hot. Then starts to splutter, governor tries to compensate (you can see it rocking to and fro), runs really rich, pops and bang and dies. Has new carb, points, plug, condenser, coil, fuel filter. Not fuel starvation as filter bulb is full and keeps filling. Any ideas? Share this post Link to post Share on other sites
Tractorhead 9,217 #2 Posted August 4, 2020 (edited) Open the Tank cap and verify if tankcap vent is not clogged. If it stay‘s with open Cap, you find the problem Edited August 4, 2020 by Tractorhead 2 Share this post Link to post Share on other sites
daveoman1966 3,882 #3 Posted August 4, 2020 Does it have a condensor? If so, replace it...about $5 item. That's the little round-bottle like thingy on the side of the coil...usually silver color. Share this post Link to post Share on other sites
Ian ORCHARD 1 #4 Posted August 4, 2020 48 minutes ago, Tractorhead said: Open the Tank cap and verify if tankcap vent is not clogged. If it stay‘s with open Cap, you find the problem Thank you so much for the reply. I did try it with the fuel tank cap off and it made no difference 1 Share this post Link to post Share on other sites
Ian ORCHARD 1 #5 Posted August 4, 2020 11 minutes ago, daveoman1966 said: Does it have a condensor? If so, replace it...about $5 item. That's the little round-bottle like thingy on the side of the coil...usually silver color. Thank you so much for the reply. I have changed the condensor... No difference I'm afraid. Share this post Link to post Share on other sites
pfrederi 20,263 #6 Posted August 4, 2020 How long does it have to sit before it will restart? If you have a spark plug tester hook it up and run with it. When the engine start to stumble does it show a consistent strong spark> Lets try to nail down as a fuel or spark issue 2 Share this post Link to post Share on other sites
Tractorhead 9,217 #7 Posted August 4, 2020 Good advice Paul, Btw Ian, did you check allready all the electrical and Ground connections for clean connectors and tight seat. oh, and Welcome to Share this post Link to post Share on other sites
