Dan.gerous 2,696 #2 Posted July 31, 2020 5 hours ago, mariuszaerox said: I'm at about the same stage with mine 😃 Share this post Link to post Share on other sites
mariuszaerox 12 #4 Posted August 1, 2020 hello, is there any instruction to adjust the carburetor in the briggs boxer? Share this post Link to post Share on other sites
mariuszaerox 12 #5 Posted August 1, 2020 Sparks is Black... Share this post Link to post Share on other sites
mariuszaerox 12 #6 Posted August 1, 2020 I do not have the strength for it anymore .... when I give all the gas, it goes weird like in the suction and sneezes in the exhaust or carburetor, one screw was missing in the intake manifold and there was a gap, I screwed it in for a moment as if it stopped and walked normally with 10 minutes under load then again the same. I pulled out the collector, I split it, I smeared it with Reinz and then nothing ... what to do Share this post Link to post Share on other sites
mariuszaerox 12 #7 Posted August 1, 2020 https://youtu.be/6PUUaUqtvXs Share this post Link to post Share on other sites
Dan.gerous 2,696 #8 Posted August 1, 2020 12 hours ago, mariuszaerox said: hello, is there any instruction to adjust the carburetor in the briggs boxer? You can find the online owners manual which gives you the instructions. I will check later and send you a link. Share this post Link to post Share on other sites
Dan.gerous 2,696 #10 Posted August 1, 2020 Should be able to find what your after here. Share this post Link to post Share on other sites
mariuszaerox 12 #11 Posted August 2, 2020 What's page ? Share this post Link to post Share on other sites
Dan.gerous 2,696 #12 Posted August 2, 2020 15 minutes ago, mariuszaerox said: What's page ? Page 16 and down in the carburettor section. Share this post Link to post Share on other sites
mariuszaerox 12 #13 Posted August 2, 2020 Wilk not be on Polish ? Share this post Link to post Share on other sites
Dan.gerous 2,696 #14 Posted August 2, 2020 42 minutes ago, mariuszaerox said: Wilk not be on Polish ? Not on here but maybe you can find it in Polish somewhere else. Possibly paste the section you want into Google translate and see if that works? 1 Share this post Link to post Share on other sites
mariuszaerox 12 #17 Posted August 4, 2020 I think I will give up ... today I also gave new gaskets under the intake manifold and then the same, the candles are black, on the cylinder closer to the steering wheel there is more black help 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,482 #18 Posted August 5, 2020 If the candles are black you must have spark to cause the black. Have you tried new candles? Garry 1 Share this post Link to post Share on other sites
mariuszaerox 12 #19 Posted August 5, 2020 candles and coil new 1 Share this post Link to post Share on other sites
mariuszaerox 12 #20 Posted August 5, 2020 near the circuit breaker I noticed that sometimes it sparkles well? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,482 #22 Posted August 6, 2020 17 hours ago, mariuszaerox said: near the circuit breaker I noticed that sometimes it sparkles well? What are you calling the circuit breaker? Is it the kill relay? It must be bolted on to provide a ground. What you you doing to make it sparkle? Garry Share this post Link to post Share on other sites
mariuszaerox 12 #23 Posted August 6, 2020 hmm here it sparkles sometimes when the engine is running 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,482 #24 Posted August 7, 2020 I did not think you could make the engine run. What is the problem with it now? It is normal for the circuit breaker to sparkle. Garry 1 Share this post Link to post Share on other sites
mariuszaerox 12 #25 Posted August 7, 2020 there is still a problem with the cylinder from the steering wheel with a spark, a black candle, and as if it goes for only one and sometimes two cylinders, I sent a video about how it works, I already got ideas ... Share this post Link to post Share on other sites
