mort 24 #1 Posted July 30, 2020 What are the reasons an Onan engine will not ignite the gas that you pour into the carburetor? I put in brand new spark plugs and checked continuity on the spark plug wires. The engine cranks but will not start. Is it a bad distributor cap? Is it a bad capacitor? I don't mind buying a bunch of parts and start swapping them out but want to make sure I buy the proper parts that could be bad. Share this post Link to post Share on other sites
oldredrider 2,553 #2 Posted July 30, 2020 Basics: you need fuel, air, fire and compression. 2 Share this post Link to post Share on other sites
lynnmor 7,577 #3 Posted July 30, 2020 There is no distributor cap, just a coil that fires both spark plugs at the same time. First thing to test is to pull a spark plug wire and stick it on a plug, ground the plug hex against a metal engine part and see if there is spark while cranking. Download the Onan manual for information about testing the coil, and other parts. You should have voltage at the coil and the ignition module will switch as the engine is rotated, the manual covers that. 1 Share this post Link to post Share on other sites
Stepney 2,351 #4 Posted July 30, 2020 Mine wound up having a bad key switch. First thing I would check is if you always are getting 12v to the + side of the coil when cranking or in the run position. 1 Share this post Link to post Share on other sites
mort 24 #5 Posted August 1, 2020 This engine is very frustrating! I have a 1983 310-8 and I have never had a problem with it at all. I have two 416-8 and one is hard to start unless I use it every week and this is the other one. So I have some good news and some frustrating news on the testing I did. First of all I tested the spark plug wires by grounding them and I was really surprised I had spark on both of them. I figured since I had spark I should be able ignite some gas in the spark plug chamber. WOW I was surprised again. The gas actually ignited. That is a first with this tractor!Then I tried it again and it didn't work but I did put a little gas in the carburetor too. I thought maybe it got flooded? I doubt it as I am only using a cap full at a time I waited 30 minutes and tried it again. It didn't work. I thought I would try putting gas in by the spark plug chambers again and then it worked. I tried it several times yesterday and today putting gas in the chamber and it won't ignite the gas. I thought I would check for spark again and it will not spark. I used a trouble light on the coil test and I do not see it pulsing (bright to dim). I think this means it is the ignition module based upon this test. What causes the spark plugs to spark? The coil? As I mentioned before I don't mind buying a bunch of parts and slowly swapping them out as time is money. Also what voltage regulator does this Onan use (20 or 35 amp)? Share this post Link to post Share on other sites
lynnmor 7,577 #6 Posted August 2, 2020 A marine squeeze bulb or an electric fuel pump in the supply line from the tank will fix the excessive cranking after a long period of non use. Did you have 12 volt power to the coil when there was no spark? Do the test in the Onan manual to test the ignition module. The ignition module turns on and off as the magnets pass it. When the power is switched off the collapse of the magnetic field in the coil which causes the high voltage spark. I believe that you have the 20 AMP system. Share this post Link to post Share on other sites
mort 24 #7 Posted August 2, 2020 I did buy an electric fuel pump and a one way check valve months back. I was going to install the one way check valve in the other horse but I got side tracked. Do I install it right before the fuel pump and fuel filter? Yes I have 12 volts to the coil and there was no spark. I did the ignition module test and it always read 12+ volts. So does that confirm 100% that it is only the ignition module that is bad or could it still be the coil too? I am asking because I did the coil ohm test at different settings and I saw no reading. Thank you! Gary Share this post Link to post Share on other sites
mort 24 #8 Posted August 2, 2020 I take that back on the coil test. I just tried it again. Actually on the primary resistance (terminals) I was getting 3.4-3.6 ohms. At the secondary resistance I was getting 13,000-16,000 ohms but just briefly. Every single time I did the test I got a quick display of 13,000-16,000 ohms and then it went to no reading. I tried everything to get it to display but it wouldn't. There is nothing wrong with my meter and nothing wrong with my hands/fingers.LOL! Thanks, Gary Share this post Link to post Share on other sites
mort 24 #9 Posted August 2, 2020 One more thing............I was looking on line and someone said this below............ Could the rotor (not the ignition module) be giving me that constant battery voltage of 12+ and not the 1-1.5 volts I should be getting with the ignition test? Onan 166-0785 Ignition Module PLEASE CHECK YOUR IGNITION ROTOR BEFORE ORDERING THIS AS IT IS ALMOST ALWAYS THE ISSUE. MICE LOVE TO GET IN BEHIND THE STATOR AND BUILD A NEST. AS SOON AS YOU TURN THE GEN OVER, IT BREAKS THE IGNITION ROTOR WHICH CAUSES NO FIRE TO THE PLUGS. ONCE YOU INSTALL THIS PART, IT IS YOURS. SO PLEASE VERIFY FIRST. Share this post Link to post Share on other sites
lynnmor 7,577 #10 Posted August 2, 2020 A check valve would go between the fuel pump and the carburetor. If you did the ignition module test correctly, then it is not switching. I believe they are aging out. If the condenser (mounted on the air filter support) is still attached to the coil, that would explain the brief reading, so disconnect it. The older black ignition trigger rotors did fail, but the newer gray ones are very reliable. Of course a mouse can destroy most anything. Share this post Link to post Share on other sites
mort 24 #11 Posted August 19, 2020 I ordered an ignition module and tried to order some new spark plug wires but Onan has them discontinued....................167-1615-01 9" long and 167-1615-04 18.5" long. Where can I get new spark plug wires and do you have a part number for them? Thanks, Mort Share this post Link to post Share on other sites
The Tuul Crib 7,338 #12 Posted August 19, 2020 On 7/30/2020 at 3:17 PM, lynnmor said: There is no distributor cap, just a coil that fires both spark plugs at the same time. First thing to test is to pull a spark plug wire and stick it on a plug, ground the plug hex against a metal engine part and see if there is spark while cranking. Download the Onan manual for information about testing the coil, and other parts. You should have voltage at the coil and the ignition module will switch as the engine is rotated, the manual covers that. Share this post Link to post Share on other sites
The Tuul Crib 7,338 #13 Posted August 19, 2020 T😎 Mort!! Share this post Link to post Share on other sites
bottjernat1 2,190 #14 Posted August 19, 2020 welcome!! id clean your points and reset them. Ive had to do this too 2 onans Share this post Link to post Share on other sites
Bill D 2,098 #16 Posted August 19, 2020 I make my own plug wires. Napa should have all the pieces you will need. Check your 9 pin connector. Make sure all connections are clean, tight and not burnt. Also check the fuse block for melted fuse holders. Replace the condenser when you replace the ignition module and make sure it is connected to the positive terminal on the coil. Also make sure the flywheel key hasn't sheared. If someone already replaced the module once they may not have torqued the flywheel properly. Bill Share this post Link to post Share on other sites
mort 24 #17 Posted August 19, 2020 Since I have never changed the ignition module on an Onan before I didn't realize I needed to take off the flywheel to get at it. What is involved on taking it off and what does it need to be torqued at? I stopped by Napa yesterday and they never suggested making my own spark plug wires. I saw online that people were selling spark plug wire kits and I thought if Napa couldn't help me with a replacement I would go that route. Where are the points located on an Onan 16 hp? I know where they are at on a Kohler. Are the points a 160-1183 and the capacitor 312-0256? I am not seeing the points in the parts manual. Can an ONAN Condenser 312-0246 be used since it is for a twin cylinder and 300VDC? Thanks, Gary Share this post Link to post Share on other sites
lynnmor 7,577 #18 Posted August 19, 2020 (edited) You need to remove the coil and the screws down there, and all of the screws holding the blower housing. There are two screws kind of hidden up from the bottom. A puller with 4 bolts is best to pull the flywheel. Loosen the center bolt 2 turns and then pull. It is all right there in the Onan manual. Flywheel bolt is torqued to 55lbs. You will need 7mm spark plug wire with 90 degree ends. Later model Onan engines had no points, I believe that WH never used the old ones with points. There is a condenser fastened to the air filter mount, I don't know if it is used just radio interference or if it does serve a purpose in the ignition, I've never replaced one. Edited August 19, 2020 by lynnmor Share this post Link to post Share on other sites
mort 24 #19 Posted August 19, 2020 Sounds good! Thanks, Mort Share this post Link to post Share on other sites
johnnymag3 2,559 #20 Posted August 21, 2020 THINK KOHLER.....................ENUFF SAID Share this post Link to post Share on other sites
mort 24 #21 Posted September 1, 2020 Where can I get a cheap puller to pull off the Onan flywheel? I really do not have plans on using it much so I really don't want to spend very much on it at all! Share this post Link to post Share on other sites
lynnmor 7,577 #22 Posted September 1, 2020 1 hour ago, mort said: Where can I get a cheap puller to pull off the Onan flywheel? I really do not have plans on using it much so I really don't want to spend very much on it at all! I made one from a piece of 3/8" steel. Just drill and tap 1/2" fine thread in the center and 4 clearance holes for a 5/16" bolt in the correct pattern. If you can't tap, weld a nut in the center. I did improve the puller bolt by turning the end to fit a 3/8" hardened washer to act as a bearing so the flywheel bolt doesn't turn back in, not necessary but watch that the flywheel doesn't re-tighten. Share this post Link to post Share on other sites
mort 24 #23 Posted September 1, 2020 I can solder but I don't weld. I have some taps but would rather buy something cheap. Anything I can buy cheap at maybe Harbor Freight? Share this post Link to post Share on other sites
pacer 3,176 #24 Posted September 1, 2020 Yes, HF has just what you need --- Bolt-Type Wheel Puller Set, $15.99$15.99, Handy for lots of other things too Share this post Link to post Share on other sites
lynnmor 7,577 #25 Posted September 1, 2020 I like to pull the cast iron flywheel with all 4 bolt holes, if it is very tight or rusted you run the risk of breaking. The HF puller will only use 2 holes. Share this post Link to post Share on other sites
