Felix 145 #1 Posted July 22, 2020 Hi. I’m needing a gear shift gator for a manual 4 speed transmission. im in the uk. is there an alternative to a genuine part? The original one is perished and split and I’m guessing that why the transmission oil is full of water😬 any help appreciated. 2 Share this post Link to post Share on other sites
Achto 32,076 #2 Posted July 22, 2020 (edited) Lowell sells them, not sure if he ships internationally. https://www.wheelhorsepartsandmore.com/transmissions.html#!/Wheel-horse-3577-shifter-boot/p/84932555/category=23548039 Edited July 22, 2020 by Achto 1 Share this post Link to post Share on other sites
Mickwhitt 5,259 #3 Posted July 22, 2020 I made one from a rubber hockey puck. Works really well. Its on my rebuild thread but I can give you more detail Mick Share this post Link to post Share on other sites
WHX?? 57,326 #4 Posted July 22, 2020 (edited) I ordered a bunch of them off fleabay for a great deal on a quantity not looking at the seller. Here it turned out Lowell was the seller! That said they are on there if @wheelhorseman doesn't ship international. https://www.ebay.com/itm/OEM-TORO-WHEEL-HORSE-SHIFTER-BOOT-PART-3577/324229711971?epid=941793947&hash=item4b7d98c863:g:lZMAAOSwCGVYBWty Edited July 22, 2020 by WHX24 1 Share this post Link to post Share on other sites
Lane Ranger 12,030 #5 Posted July 22, 2020 This is one item I made several replacement boots out of tennis balls! They are thicker and can be cut with a hack saw on bottom and drilled through on top for shifter! These will last longer than the Wheel Horse boot! 2 2 Share this post Link to post Share on other sites
SylvanLakeWH 31,673 #6 Posted July 22, 2020 8 minutes ago, Lane Ranger said: This is one item I made several replacement boots out of tennis balls! They are thicker and can be cut with a hack saw on bottom and drilled through on top for shifter! These will last longer than the Wheel Horse boot! Great idea! Just one question - where did you find Regal Red or black tennis balls? 1 Share this post Link to post Share on other sites
wheelhorseman 3,256 #7 Posted July 22, 2020 56 minutes ago, Achto said: Lowell sells them, not sure if he ships internationally. https://www.wheelhorsepartsandmore.com/transmissions.html#!/Wheel-horse-3577-shifter-boot/p/84932555/category=23548039 Yes we ship international in fact we have a box going to the UK in a week or 2 1 2 Share this post Link to post Share on other sites
Lane Ranger 12,030 #8 Posted July 22, 2020 6 minutes ago, SylvanLakeWH said: Great idea! Just one question - where did you find Regal Red or black tennis balls? etsy is you have to have matching! Or it does take quite a bit of paint to fill in the tennis ball fuzz! 1 1 2 Share this post Link to post Share on other sites
Felix 145 #9 Posted July 22, 2020 51 minutes ago, Lane Ranger said: This is one item I made several replacement boots out of tennis balls! They are thicker and can be cut with a hack saw on bottom and drilled through on top for shifter! These will last longer than the Wheel Horse boot! I will give the tennis ball trick ago. sounds good. Is it a tight fit on the gearbox or would it need a jubilee clip to secure it? 1 Share this post Link to post Share on other sites
Lane Ranger 12,030 #10 Posted July 22, 2020 (edited) The size of the top cut determines how tight the rest of the ball fits over the shifter and the transmission . No clips should be needed! Edited July 22, 2020 by Lane Ranger Share this post Link to post Share on other sites
peter lena 9,938 #11 Posted July 22, 2020 FELIX, your stating of water in the transmission , makes me say do a couple of lighter oil flushes on that gear box , with the front end raised for better drainage. i like ATF FLUID , or kerosene , and a thorough use of all the gears and hi/lo ranges . picture what you are trying to do , getting rid of water in those bearings and sliders , more detail will make it shift like new . regular gear oil would be 75-90 wt or 75- 140 wt . let us know how you make out , pete 2 Share this post Link to post Share on other sites
Lane Ranger 12,030 #12 Posted July 22, 2020 Ok I found some pics from 2019 (last time I made one of the tennis ball boots for a Wheel Horse shifter on the transmission). This may give you a better idea how to make one of these tennis ball boots for your tractor! 2 1 Share this post Link to post Share on other sites
roadapples 6,987 #13 Posted July 22, 2020 Good idea Lane, but wouldn't it be better to drill the top hole for a tighter fit on the rod... 1 Share this post Link to post Share on other sites
Lane Ranger 12,030 #14 Posted July 22, 2020 I usually do with a wood bit but this was a quick job on a Work tractor. You do have to cut bottom out first before drilling! 3 Share this post Link to post Share on other sites
WHX?? 57,326 #15 Posted July 22, 2020 I dunno Lane ...takes al lot of balls to take a tractor out dressed like that! 1 1 Share this post Link to post Share on other sites
