AHS 1,698 #1 Posted July 21, 2020 Ok, this Wheelhorse has really impressed me!! It’s the cash mower, that I mow two lawns every two weeks... 1 of the lawns is good size. It’s been hot out... 85-90 degrees... and it’s still mowed. The Kohler M14😀👍💪It’s had two oil changes and 1 tranny fluid change. I believe it’s time for paint this fall.. and decals!! This winter it’ll see the tall Shute snowblower!! 6 2 2 Share this post Link to post Share on other sites
ebinmaine 80,614 #2 Posted July 21, 2020 Great dependability. Time to spiff it up! 1 Share this post Link to post Share on other sites
Pollack Pete 2,273 #3 Posted July 21, 2020 Great model.Lots of power.I've got one that I use occasionaly.Don't make it too pretty.You won't want to use it. 2 Share this post Link to post Share on other sites
The Tuul Crib 7,354 #4 Posted July 21, 2020 (edited) Ditto that! My 414 runs strong and long! Dont know what l would do with out it!! Edited July 21, 2020 by The Tuul Crib 2 1 Share this post Link to post Share on other sites
Rob R 989 #5 Posted July 21, 2020 No Trailer Queens here! 1 1 1 Share this post Link to post Share on other sites
peter lena 10,047 #6 Posted July 21, 2020 AHS , great to hear that you actually change oil and trans fluid, what a concept !. rotella 30 wt oil has the extra zinc these engines love . in the mean time you could feed the paint and stop surface rust with a regular rubdown of penetrating oil or mmo, on a clean rag . it will add a patina and a solid base for painting. take the time to regularly drop the deck and clean out any build up, lucas RED nd tacky grease IN THE DECK SPINDLES , does a very good job. pete 3 Share this post Link to post Share on other sites
lynnmor 9,037 #7 Posted July 21, 2020 Kohler now puts the extra zinc information right on the label, no need to run diesel oil or the SN government approved stuff. 1 1 Share this post Link to post Share on other sites
Tractorhead 9,217 #8 Posted July 21, 2020 Nice Rig, great to have a solid worker aside. Good decision to keep the fluids changed regulary, regular maintanance give you mostly a Longterm troublefree Seattime. Have longtime Fun with it! 2 Share this post Link to post Share on other sites
AHS 1,698 #9 Posted July 21, 2020 10 hours ago, Rob R said: No Trailer Queens here! @Pollack Pete 😀 Share this post Link to post Share on other sites
AHS 1,698 #10 Posted July 21, 2020 12 hours ago, ebinmaine said: Great dependability. Time to spiff it up! Yup!! I wanted to make sure the 414 was a good worker...a little smoke when I first got it... but in the past oil changes there has been no smoke to speak of!! I’ve been paying close attention to the magnum series vs the K series, they seem to be awful close... except no coil on this one. Every time I go out there and start it up.. it only turns over once before it’s started!! 😀 like a Kohler!!💪. 2 1 Share this post Link to post Share on other sites
D_Mac 9,339 #11 Posted July 21, 2020 (edited) Love the Magnum engines. I have a 1988 416-8 that I just finished up " refreshing " . Its condition was in similar shape to yours. Check out my post in the Restoration section to see what I did to mine. A little bit of paint and a lot of elbow grease and a new set of decals will go a long ways. Edited July 21, 2020 by D_Mac 2 Share this post Link to post Share on other sites
AHS 1,698 #12 Posted July 22, 2020 1 hour ago, D_Mac said: Love the Magnum engines. I have a 1988 416-8 that I just finished up " refreshing " . Its condition was in similar shape to yours. Check out my post in the Restoration section to see what I did to mine. A little bit of paint and a lot of elbow grease and a new set of decals will go a long ways. NICE NICE NICE!!!! 416-8.... that’s my dream machine right there!! 1 Share this post Link to post Share on other sites
Redneckdavis 308 #13 Posted July 22, 2020 Also in addition to diesel oils. Any "break in" oil or the Valvoline VR1, have the zinc the flat tappet cams need. . Or you could use whatever oil you have/like and put the zinc additive in. That's what I was doing with my vehicles before I swapped to vr1 and rotella 1 Share this post Link to post Share on other sites
Cabintime 3 #14 Posted July 22, 2020 New to the site this morning. Picked up a 414-8 1989 yesterday and will begin evaluating soon. What is this need for zinc mentioned in the oil? Looking forward learning and appreciating the Wheel Horse. 3 Share this post Link to post Share on other sites
peter lena 10,047 #15 Posted July 22, 2020 the kohler engines are an old design and from a different era, before emissions , they also have flat tappet cams calling for more zinc to make them operate efficiently and quieter. while you are at it , try and change your oil after thoroughly getting it hot , for a more thorough drain out and deposit removal. use a straight 30 wt oil , like rotella in the hot weather , and a 5 - 30 oil , also rotella in the winter . we all have our own favorite oils , if nothing else , get a zinc enriched oil for best results. drain your transmission , by lifting the front end to increase its discharge. with front end lifted , grease your front axle , 3 fittings . transmission oil , 75-90 0r 75-140 . check your shifter boot , its probably cracked or torn , replace it, easy to find on line. remove boot with a razor blade install with grease on the shifter lever and boot center hole . this is just basic lubrication maintenance. let us know how you are making out , pete 2 Share this post Link to post Share on other sites
lynnmor 9,037 #16 Posted July 22, 2020 47 minutes ago, Cabintime said: New to the site this morning. Picked up a 414-8 1989 yesterday and will begin evaluating soon. What is this need for zinc mentioned in the oil? Looking forward learning and appreciating the Wheel Horse. It is an anti-wear additive used for 3/4 of a century that will lessen wear in any kind of engine, not just the flat tappet engines. The government wants the ZDDP out of the oil so we now have most oils with the API SN designation that is not a good thing for your Kohler. The thing with flat tappet designs it that the failures are catastrophic instead of just long term degradation. Click here for more information. Know that just using additive can be a problem because you may not mix in the optimum amount, too much is just as bad as too little and the original amount may not be known. Many complain about ethanol in their gas, soybeans in their diesel fuel, but don't realize what is going on with oil. Share this post Link to post Share on other sites
AHS 1,698 #17 Posted July 22, 2020 This is what I use, 1/2 a bottle. Share this post Link to post Share on other sites
lynnmor 9,037 #18 Posted July 22, 2020 37 minutes ago, AHS said: This is what I use, 1/2 a bottle. Nearly all oil contains ZDDP, just less than what was used in the good old days. This STP additive has a trivial amount and will actually lower the PPM of your oil. My opinion is that it is just another snake oil. Here is a video that includes an oil analysis. 1 Share this post Link to post Share on other sites
ebinmaine 80,614 #19 Posted July 22, 2020 41 minutes ago, lynnmor said: Nearly all oil contains ZDDP, just less than what was used in the good old days. This STP additive has a trivial amount and will actually lower the PPM of your oil. My opinion is that it is just another snake oil. Here is a video that includes an oil analysis. Interesting watch. Thanks for sharing that. I've never been much of a fan of most additives though I realize some do better than others. Share this post Link to post Share on other sites
AHS 1,698 #20 Posted July 22, 2020 42 minutes ago, lynnmor said: Nearly all oil contains ZDDP, just less than what was used in the good old days. This STP additive has a trivial amount and will actually lower the PPM of your oil. My opinion is that it is just another snake oil. Here is a video that includes an oil analysis. Well that was a good speak. I dunno if I’m gonna use it again... I would never use it in the winter!! Share this post Link to post Share on other sites
ebinmaine 80,614 #21 Posted July 22, 2020 Back about 30 years ago I worked with a fella who was self admitted 3 weeks older than dirt. He's been messing with cars trucks tractors etc since the 1930s. He told us one time of why he didn't use STP. Before the days of detergent oils there would be a residue in the oil pan bottom that was just another part of regular maintenance to clean out. He worked on a customer's engine that had seen PLENTY of STP over it's years. It lost oil pressure and quit. When they disassembled it to determine the cause they found the oil pan nearly full of old oil/STP sludge cut exactly to the shape of the spinning crankshaft. Sort of a gel... 1 Share this post Link to post Share on other sites
AHS 1,698 #22 Posted July 23, 2020 1 hour ago, ebinmaine said: Back about 30 years ago I worked with a fella who was self admitted 3 weeks older than dirt. He's been messing with cars trucks tractors etc since the 1930s. He told us one time of why he didn't use STP. Before the days of detergent oils there would be a residue in the oil pan bottom that was just another part of regular maintenance to clean out. He worked on a customer's engine that had seen PLENTY of STP over it's years. It lost oil pressure and quit. When they disassembled it to determine the cause they found the oil pan nearly full of old oil/STP sludge cut exactly to the shape of the spinning crankshaft. Sort of a gel... WOW!! The YouTube video of STP made it seem like it was plenty thick during engine running; I was thinking it was not! 1 Share this post Link to post Share on other sites
kick 86 #23 Posted July 24, 2020 I’m a broken record but the single kohler 8 speeds are some of the best horses ever made period. 3 Share this post Link to post Share on other sites
AHS 1,698 #24 Posted July 24, 2020 7 hours ago, kick said: I’m a broken record but the single kohler 8 speeds are some of the best horses ever made period. I haven’t found one YET!!😀 Share this post Link to post Share on other sites
953 nut 69,143 #25 Posted July 24, 2020 On 7/21/2020 at 9:59 AM, lynnmor said: Kohler now puts the extra zinc information right on the label, no need to run diesel oil or the SN government approved stuff. That is a 10 W 30 oil. there is information in Kohler owner manuals that warns you to only use 10 W 30 in cold conditions in splash lubricated engines. Share this post Link to post Share on other sites
