Silveradojeff 13 #1 Posted July 16, 2020 The o’l 520 looks a lil better after pressure washing and a new seat. Runs great and hydraulics work well. Still a long ways to go 7 Share this post Link to post Share on other sites
WheelhorseBob 1,550 #2 Posted July 17, 2020 Just got a 520 myself. Been reading everything I can on them.have fun with it! 1 Share this post Link to post Share on other sites
Silveradojeff 13 #3 Posted July 18, 2020 8 hours ago, WheelhorseBob said: Just got a 520 myself. Been reading everything I can on them.have fun with it! This is my first. I’ve got a lot to learn about the 520 also. It’s a lot different than the mowers I usually work on but I’m having fun with it. Congrats on ur purchase Share this post Link to post Share on other sites
Pollack Pete 2,273 #4 Posted July 18, 2020 Lookin' good.Get those hub caps shined up! Share this post Link to post Share on other sites
bds1984 1,508 #5 Posted July 18, 2020 She is still better looking than mine! I bet that with some wet sanding and oiling on the paint, it'll clean up even more. 1 Share this post Link to post Share on other sites
Lee1977 7,638 #6 Posted July 18, 2020 The first thing you should is pull the fender pan, tunnel cover, lower hood stand cover and the engine covers and remove all the dirt grass and oil from it. Here is just a sample of what you'll find. I had already cleaned the engine, hydro and tunnel. Here are a cople of pictures after cleaning and treating the rust Share this post Link to post Share on other sites
peter lena 9,896 #7 Posted July 18, 2020 having done this a number of times , but not on a 520, i would go after the most obvious , rust and corrosion , i also have a two bolt flange bearing on the steering column to cross mount plate , on all three of my tractors , great opportunity . also a good time to washer up the PTO LEVER PLAY at side base of the battery tray,i used both steel and teflon washers and silicone grease , very solid smooth action. clean up and sand every electrical contact point and dielectric grease all slide ons , including fuses . also as you correct things refer back to what you have , so if you caused a problem , go back and verify the correction. keep us informed ,pete Share this post Link to post Share on other sites
