71_Bronco 1,072 #1 Posted July 6, 2020 Going to be working on my 8hp Commando 8 motor soon, and one thing I'm not looking forward to is removing the tripple pulley on the crank of the motor. There is no drilled & tapped holes to thread in puller bolts. Does anybody have any hints or tricks to getting this off? Thanks! Share this post Link to post Share on other sites
Pullstart 71,332 #2 Posted July 6, 2020 If you can start some wedges in there, like construction shims... and work up to pickle fork / tie rod tools... you might be able to tap it off the crank. Shim from both sides, to keep the wedge pressing parallel on the pulley. 2 1 Share this post Link to post Share on other sites
bc.gold 3,406 #3 Posted July 6, 2020 1 hour ago, 71_Bronco said: Going to be working on my 8hp Commando 8 motor soon, and one thing I'm not looking forward to is removing the tripple pulley on the crank of the motor. There is no drilled & tapped holes to thread in puller bolts. Does anybody have any hints or tricks to getting this off? Thanks! Bearing splitter is made for such a task. 3 2 Share this post Link to post Share on other sites
bc.gold 3,406 #4 Posted July 6, 2020 41 minutes ago, pullstart said: If you can start some wedges in there, like construction shims... and work up to pickle fork / tie rod tools... you might be able to tap it off the crank. Shim from both sides, to keep the wedge pressing parallel on the pulley. Thought you were taking a nap. 1 Share this post Link to post Share on other sites
Pullstart 71,332 #5 Posted July 6, 2020 1 hour ago, bcgold said: Thought you were taking a nap. rumble strip.... just outside of Memphis on US-55! 1 1 Share this post Link to post Share on other sites
ebinmaine 80,772 #6 Posted July 6, 2020 I used a 3 jaw puller. Caught one of the grooves that was flat toward the puller. Got it all set up then wrapped the puller with a band clamp so it couldn't come off. That was before I had a set of pullers like mentioned above... 2 Share this post Link to post Share on other sites
JoeM 10,311 #7 Posted July 6, 2020 Wedges and tapping the shaft lightly. Some of those pulleys had a thicker area between groves, if you use a puller make sure you are behind the thicker ring. 2 Share this post Link to post Share on other sites
WHX?? 58,236 #8 Posted July 6, 2020 Polish the exposed crank and use plenty of lube. 1 Share this post Link to post Share on other sites
clueless 3,439 #9 Posted July 6, 2020 29 minutes ago, WHX24 said: Polish the exposed crank and use plenty of lube. Okay everybody let's not go there 5 Share this post Link to post Share on other sites
squonk 48,166 #10 Posted July 6, 2020 Bearing separator and puller on the separator. Jaw puller can damage the pulley 1 Share this post Link to post Share on other sites
WHX?? 58,236 #11 Posted July 6, 2020 4 minutes ago, clueless said: Okay everybody let's not go there I never even went there till you just said something! 3 Share this post Link to post Share on other sites
squonk 48,166 #12 Posted July 9, 2020 Here's the set up: 1 1 Share this post Link to post Share on other sites
953 nut 69,571 #13 Posted July 9, 2020 Mike's @squonk set up in the previous post is the way to go. I use an air impact gun to run the bolt in on the puller and if it isn't moving give the end of the puller bolt a couple of blows with a BFH tool to shock it. Some times there will be enough rust between the pulley and shaft that you will need to heat the pulley to get it moving. Share this post Link to post Share on other sites
WHX?? 58,236 #14 Posted July 9, 2020 Mike you need to clean your crank before you start pulling on it & squirt some lube down that screw hole. 1 Share this post Link to post Share on other sites
squonk 48,166 #15 Posted July 9, 2020 (edited) 10 minutes ago, WHX24 said: Mike you need to clean your crank before you start pulling on it & squirt some lube down that screw hole. Came right off. Grey stuff on threads is lube. Couple raps with the Dee-Walt 3/8” impact and it was in my hands Edited July 9, 2020 by squonk 1 Share this post Link to post Share on other sites
