fast88pu 3,394 #26 Posted November 15, 2020 9 minutes ago, WVHillbilly520H said: I got a better deal on this one as it was 2 year left over, I love it but the overrunning clutch on the PTO took a bit to get used but I have 3 acres of hills to mow put in gear set the hand throttle (has foot throttle too) and set back... Got a 56" Snow blower and 62" plow coming (estimated delivery Dec-Feb) for it this winter as well as a soft cab. Where did you find a soft cab for it? Share this post Link to post Share on other sites
WVHillbilly520H 10,379 #27 Posted November 15, 2020 12 minutes ago, fast88pu said: Where did you find a soft cab for it? Bercomac makes them, but I had a Mahindra dealer order it all. 1 Share this post Link to post Share on other sites
c-series don 12,524 #28 Posted November 15, 2020 Here’s my son in law delivering a new grill with my C-141 3 Share this post Link to post Share on other sites
Zeek 2,299 #29 Posted November 15, 2020 I have a grapple and pallet forks, both of which I use more than the bucket. I guess it will depend on what you are doing. I got some pallet racks so I can store the implements out of the way when not in use. They are the quick-detach skid steer type. 7 1 Share this post Link to post Share on other sites
fast88pu 3,394 #30 Posted November 15, 2020 15 hours ago, WVHillbilly520H said: Bercomac makes them, but I had a Mahindra dealer order it all. O ok. They make a good blower. Share this post Link to post Share on other sites
fast88pu 3,394 #31 Posted November 15, 2020 4 hours ago, Zeek said: I have a grapple and pallet forks, both of which I use more than the bucket. I guess it will depend on what you are doing. I got some pallet racks so I can store the implements out of the way when not in use. They are the quick-detach skid steer type. Who did you buy the 3rd function from for the grapple? Share this post Link to post Share on other sites
fast88pu 3,394 #32 Posted November 15, 2020 I have been moving logs and stumps and firewood lately with mine. I also added hooks to the bucket and LED light and also a thumb for the backhoe. 2 1 Share this post Link to post Share on other sites
WVHillbilly520H 10,379 #33 Posted November 15, 2020 44 minutes ago, fast88pu said: O ok. They make a good blower. Bercomac in Canada makes everything for the Mahindra/TYM then rebadged I'm pretty sure they build the snowblowers for Kubota and JD as well ... I would like a backhoe for 1 of mine but then everybody else would want me digging holes for them. 1 Share this post Link to post Share on other sites
fast88pu 3,394 #34 Posted November 15, 2020 2 hours ago, WVHillbilly520H said: Bercomac in Canada makes everything for the Mahindra/TYM then rebadged I'm pretty sure they build the snowblowers for Kubota and JD as well ... I would like a backhoe for 1 of mine but then everybody else would want me digging holes for them. I picked up this older bare foot fabrication 60" 3pt blower. Another older Canadian company that made blowers. Share this post Link to post Share on other sites
WVHillbilly520H 10,379 #35 Posted November 15, 2020 49 minutes ago, fast88pu said: I picked up this older bare foot fabrication 60" 3pt blower. Another older Canadian company that made blowers. Looks like a decent unit, rear PTO 3pt unit like that would be fine on short/small areas, but I have our and her parents driveways plus the snow/dozer blade uses the same under tractor sub frame... Basically just a newer version 4wd WH IMO ... mow, till, landscape, snow duties. 1 Share this post Link to post Share on other sites
Zeek 2,299 #36 Posted November 16, 2020 20 hours ago, fast88pu said: Who did you buy the 3rd function from for the grapple? The TYM dealer installed it when I bought it. Share this post Link to post Share on other sites
GrandpaRay 6 #37 Posted November 23, 2020 thought you guys might like to see the FEL @elliot ness built a few years ago. My brother in Kansas purchased it and then it found it's way to me in NE Ohio a few years ago. My father in law helped me get it onto a different 520. It's held up really well. I added the tiller for counter weight and then welded a pole for some old workout weights and a crate. Thank you @elliot ness! Well done. 4 1 Share this post Link to post Share on other sites
WVHillbilly520H 10,379 #38 Posted November 23, 2020 Just for giggles... My 520 parked in/under the Mahindra's FEL what do you all think? 2 1 1 Share this post Link to post Share on other sites
ebinmaine 80,957 #39 Posted November 23, 2020 1 hour ago, WVHillbilly520H said: Just for giggles... My 520 parked in/under the Mahindra's FEL what do you all think? Looks perfect. You should oughtta get out yer welder and pop together a subframe on the horse. Share this post Link to post Share on other sites
WVHillbilly520H 10,379 #40 Posted November 23, 2020 47 minutes ago, ebinmaine said: Looks perfect. You should oughtta get out yer welder and pop together a subframe on the horse. Unfortunately with the horses you need a seperate hydraulic reservoir and pump... Where the eMax the trans is the both. Share this post Link to post Share on other sites
fast88pu 3,394 #41 Posted November 25, 2020 On November 23, 2020 at 4:49 PM, WVHillbilly520H said: Just for giggles... My 520 parked in/under the Mahindra's FEL what do you all think? Surprising how good it would fit size wise compared to the 520 1 1 Share this post Link to post Share on other sites
ecsi635j 34 #42 Posted November 25, 2020 Would be "Awesome" if you could adapt it somehow! 1 Share this post Link to post Share on other sites
Pullstart 71,367 #43 Posted November 25, 2020 On 11/23/2020 at 4:14 PM, GrandpaRay said: thought you guys might like to see the FEL @elliot ness built a few years ago. My brother in Kansas purchased it and then it found it's way to me in NE Ohio a few years ago. My father in law helped me get it onto a different 520. It's held up really well. I added the tiller for counter weight and then welded a pole for some old workout weights and a crate. Thank you @elliot ness! Well done. Nice rig! I too thought about adapting a tiller to the rear of a FEL tractor. Imagine if there is hard dirt to move, just fluff it up a tad bit before scooping it up! 2 Share this post Link to post Share on other sites
