grinchsr 675 #1 Posted June 20, 2020 Picked up a 1995 520 with gear reduction. My question is about the play in the steering. There seems to be some play between the 2 stacked gears. Is there a adjustment I can make to bring the 2 gears a bit closer with out binding them. Rest of the front end is tight. Share this post Link to post Share on other sites
cleat 9,405 #2 Posted June 20, 2020 Yes, the lower gear bolts on from below and there should be some factory shims you can remove to tighten things up a bit. Share this post Link to post Share on other sites
lynnmor 9,073 #3 Posted June 20, 2020 I guess that you already adjusted the nut in front of the fan gear? Share this post Link to post Share on other sites
grinchsr 675 #4 Posted June 20, 2020 Thanks for the responses. I have to get this tractor back on the lift and take a look Share this post Link to post Share on other sites
