oilwell1415 563 #26 Posted June 19, 2020 I look at gauges like this: Does it tell me anything that's going to make me change what I'm doing when I look at it? Hour meter? No. Oil pressure (if appropriate)? Yes. Oil temperature? Yes. CHT? Yes. Voltage? Yes. Amperage? Yes. Tachometer? No. Fuel level? Yes. Hydraulic pressure and fluid temp (if appropriate)? Yes. Share this post Link to post Share on other sites
meadowfield 3,003 #27 Posted June 19, 2020 2 hours ago, Rob R said: LUV the RPM dial indicator (WH) where can I get one, what is the cost and how is it installed. THANKS I've made these from cheap chinese ones. Theres a thread from about 6 years ago somewhere... Share this post Link to post Share on other sites
meadowfield 3,003 #28 Posted June 19, 2020 53 minutes ago, bcgold said: My Mitsubishi Pajero had a factory installed inclinometer don't need that, if my beer spills then slope is too steep 1 4 1 Share this post Link to post Share on other sites
meadowfield 3,003 #29 Posted June 19, 2020 29 minutes ago, oilwell1415 said: I look at gauges like this: Does it tell me anything that's going to make me change what I'm doing when I look at it? Hour meter? No. Oil pressure (if appropriate)? Yes. Oil temperature? Yes. CHT? Yes. Voltage? Yes. Amperage? Yes. Tachometer? No. Fuel level? Yes. Hydraulic pressure and fluid temp (if appropriate)? Yes. not far off then - but long term knowing hours is good for oil changes. Tacho just looks cool and tells you engine is spinning 1 Share this post Link to post Share on other sites
Tractorhead 9,217 #30 Posted June 19, 2020 @meadowfield i tryed the rpm / fuel gauge combo on my 212, because the fueltank is under the hood, but i found that it works not pretty well. this combo can be seen on the right side of the Dash outside. - yap, i know wrong steering wheel but this was just one i had laying aside and no the Airbag wasn‘t in it - 😂 if it shows the Fueltank is empty i‘m close to half full. even after i had calibrated it as the manufacturer suggested several times. The reaction of that fuel gauge is pretty slow. On my Beast i have the transparent pipe version, that works really well for me. A quick view and i‘m informed about fuel. it is a good indicator for long term trips, not to reach the „never comeback“ line. 2 Share this post Link to post Share on other sites
oilwell1415 563 #31 Posted June 19, 2020 8 minutes ago, meadowfield said: not far off then - but long term knowing hours is good for oil changes. Tacho just looks cool and tells you engine is spinning I agree it's good to know the hours, but you're not going to hit 50 hours and stop what you're doing for an oil change. Someone like me that doesn't use it very often can just change it every year and be OK with it. If it's a piece of equipment that gets used all day every day you should probably just put an oil change on the list of things to do every Friday afternoon before you call it a day. In between those two extremes or to know how many hours are on it when it's time to sell it I would say are exceptions. But I consider an hour meter to provide strategic information and I wouldn't take up space on the instrument panel for it. I'd save that for tactical information that makes a difference right now. Share this post Link to post Share on other sites
WHX?? 56,800 #32 Posted June 19, 2020 2 hours ago, Stormin said: Maybe I'm just an old foggie, but I'm another for the K.I.S.S. principle. True Norm.... I still say load her up Mark! 1 2 Share this post Link to post Share on other sites
squonk 46,773 #33 Posted June 19, 2020 6 minutes ago, WHX24 said: True Norm.... I still say load her up Mark! You're getting awful close to "gimbal lock" Jim! 1 Share this post Link to post Share on other sites
Stormin 9,988 #34 Posted June 19, 2020 36 minutes ago, squonk said: You're getting awful close to "gimbal lock" Jim! That sounds painfull. 1 2 Share this post Link to post Share on other sites
Tractorhead 9,217 #35 Posted June 19, 2020 (edited) 2 hours ago, WHX24 said: True Norm.... I still say load her up Mark! But this turns slightly back to be Cool.. 😎 you just need a computered Voice in background that said continousely „Too much input, too much input“ 😂😂😂 Edited June 19, 2020 by Tractorhead Share this post Link to post Share on other sites
pfrederi 20,629 #36 Posted June 19, 2020 or maybe HAL I'm sorry, Dave. I'm afraid I can't do that. Dave Bowman : What's the problem? HAL : I think you know what the problem is just as well as I do. Dave Bowman : What are you talking about, HAL? HAL : This mission is too important for me to allow you to jeopardize it. 2 Share this post Link to post Share on other sites
71_Bronco 1,072 #37 Posted June 20, 2020 I think you should go digital.... then add a voice module.... and call it W.H.I.T.T. 1 1 Share this post Link to post Share on other sites
CCW 1,505 #38 Posted June 20, 2020 20 hours ago, ebinmaine said: If I had one of those the only time it would be AT 0 is when that given tractor was parked in the basement for maintenance. Even WHAT I consider to be flat spots in the yard still have a slight grade for water runoff. You could always mount this on the hood. 1 Share this post Link to post Share on other sites
Dan.gerous 2,696 #39 Posted June 21, 2020 On 6/20/2020 at 1:53 PM, CCW said: You could always mount this on the hood. Our even better, get one of the instrument clusters that the old 4wd vehicles used to have on top of the dash. Would bolt on there nicely. Share this post Link to post Share on other sites
meadowfield 3,003 #40 Posted June 22, 2020 Installed the oil sender yesterday.... as the oil was new and didn’t want to drain it - I had to be ingenious good job I have my crane... I wasn’t sure whether the pan was 3/8 or 1/2 NPT so bought a mix of adapters. The sender is 1/8” bsp. proof that no oil was lost finished and in place. now to make the wiring loom - as this tractor had nothing! 3 Share this post Link to post Share on other sites
WHX?? 56,800 #41 Posted June 22, 2020 What's your plan to drain the oil, just remove the sender? No room to put a tee in there? 1 Share this post Link to post Share on other sites
meadowfield 3,003 #42 Posted June 22, 2020 (edited) 1 hour ago, WHX24 said: What's your plan to drain the oil, just remove the sender? No room to put a tee in there? yeah, a long 9/16 socket fits over the whole lot. Just the wire to pull... I figure it will read quicker if the sender is in the pan - though the oil and pan will all get to temp. Edited June 22, 2020 by meadowfield Share this post Link to post Share on other sites
bds1984 1,508 #43 Posted June 23, 2020 Although I do not have an oil temp sensor, I do have a tachometer, fuel gauge, ammeter, volt meter, and hour meter on my C165. I the engine was pressure lube, I'd definitely have an oil pressure gauge on it. Share this post Link to post Share on other sites
meadowfield 3,003 #44 Posted June 28, 2020 Final gauge came, all wired in and working. Not had engine hot enough yet to move the oil temp. 2 Share this post Link to post Share on other sites
