stevebo-(Moderator) 8,741 #1 Posted June 15, 2020 Hello all. I have a 522xi that has be stumped. Picked up non running. It will only run on choke and not that good....Here is what I did to it. 1. Checked fuel to ensure that it flows good from tank 2. Replaced all fuel lines including vac line to fuel pump 3. Changed filter 4. Changed fuel pump 5. Cleaned car and set mixture to spec (1 1/2 turns) 6. Tried a proven carb on it from another 520xi I own 7. Swapped plugs with another one I own 8. Checked spark on both plugs and good 9. Filled with good gas I am at a loss here. Will ONLY run with choke fully on. Battery is weak but gets it to start. Could the battery be the issue? Any advise would be appreciated. Thanks!! Share this post Link to post Share on other sites
WHX?? 57,470 #2 Posted June 15, 2020 (edited) That is bizzare. Sounds you covered all the fuel related issues and that it is starved for fuel. Check the intake manifold for leakage? Not enough vacuum to draw fuel? Edited June 15, 2020 by WHX24 2 Share this post Link to post Share on other sites
stevebo-(Moderator) 8,741 #3 Posted June 15, 2020 I did spray wd at the base of the carb and no change. The base gasket is used but could need replacing? Share this post Link to post Share on other sites
squonk 47,423 #4 Posted June 15, 2020 My first thought is some kind of vacuum leak. Air leaking in leans out the cylinder mixture so you have to cut off the incoming air at the carb with the choke to get the mixture close. Also closing choke increases engine vacuum so it can pull fuel out of carb Share this post Link to post Share on other sites
squonk 47,423 #5 Posted June 15, 2020 Does this engine have any kind of intake manifold? Share this post Link to post Share on other sites
WHX?? 57,470 #6 Posted June 15, 2020 Should be a Command CH with a V looking manifold, block gaskets but guessing you sprayed them. Possible breather issue? Share this post Link to post Share on other sites
lynnmor 8,915 #7 Posted June 15, 2020 Maybe some junk in the fuel lines plugged both carburetors, I would make another attempt at cleaning. Share this post Link to post Share on other sites
squonk 47,423 #8 Posted June 15, 2020 Any vacuum hoses on this beast? ( I got a $50 tip one day due to a hole in one of them critters) Share this post Link to post Share on other sites
stevebo-(Moderator) 8,741 #9 Posted June 15, 2020 It has an intake with two runners. Could be there but man this is kicking my tail. Tried two new plugs and all new fresh gas again Share this post Link to post Share on other sites
stevebo-(Moderator) 8,741 #10 Posted June 15, 2020 I think the only vacuum is the one to the fuel pump which I replaced Share this post Link to post Share on other sites
Shynon 7,604 #11 Posted June 15, 2020 Steve there is a little brearher tab that I have heard can break. Thus having no crank case vacuum. Pics from my 518XI Share this post Link to post Share on other sites
SylvanLakeWH 31,769 #12 Posted June 15, 2020 Do those have gas cap vents that typically plug like the older ones? Just a thought... Share this post Link to post Share on other sites
JoeM 10,101 #13 Posted June 16, 2020 I am interested because my daughters 520xi will be running great, then shuts off like it ran out of fuel. I changed some of the fuel lines, filter and the fuel pump. I can only start it back up and run it on choke. After a few minutes, it runs fine. Good gas, good flow from the tank, pump seems to be putting out. I ran the engine with the pump discharge into a plastic bottle, seems, okay. I did notice when this problem happens there is very little fuel in the filter.?? typically it is about half full. Just about ready to install an electric fuel pump. Trouble is, I got to cut grass for about 20 minutes to get it good and hot before the problem shows up. Might install the pump and go for a burn this weekend. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,371 #14 Posted June 16, 2020 This service bulletin includes fuel tank vent. Garry 1 Share this post Link to post Share on other sites
shallowwatersailor 3,221 #15 Posted June 16, 2020 Two things to try - and both might not work. Jumper the seat switch out, and try a different battery. I think I had trouble one time with either my 518xi or 520xi with the way it ran. Swapped batteries and it ran fine. 2 Share this post Link to post Share on other sites
JoeM 10,101 #16 Posted June 16, 2020 9 hours ago, shallowwatersailor said: Jumper the seat switch out My 520 LXI seat switch was bad. At times it would have high resistance and the engine would start "breaking up". I twas random problem. These machines are still a beast 9 hours ago, gwest_ca said: fuel tank vent going to check that today Share this post Link to post Share on other sites
JoeM 10,101 #17 Posted June 16, 2020 15 hours ago, gwest_ca said: service bulletin Checked the xi vent today, definitely an issue. Pics are how it was when I removed the seat pan. That hose has never been in the correct position. Also, someone cut off the seat switch wiring plug, twisted the wires together and tape. 1 Share this post Link to post Share on other sites
stevebo-(Moderator) 8,741 #18 Posted June 17, 2020 On 6/15/2020 at 8:28 PM, TractorJunkie said: I am interested because my daughters 520xi will be running great, then shuts off like it ran out of fuel. I changed some of the fuel lines, filter and the fuel pump. I can only start it back up and run it on choke. After a few minutes, it runs fine. Good gas, good flow from the tank, pump seems to be putting out. I ran the engine with the pump discharge into a plastic bottle, seems, okay. I did notice when this problem happens there is very little fuel in the filter.?? typically it is about half full. Just about ready to install an electric fuel pump. Trouble is, I got to cut grass for about 20 minutes to get it good and hot before the problem shows up. Might install the pump and go for a burn this weekend. That is what happens with my neighbors 522xi On 6/15/2020 at 8:44 PM, shallowwatersailor said: Two things to try - and both might not work. Jumper the seat switch out, and try a different battery. I think I had trouble one time with either my 518xi or 520xi with the way it ran. Swapped batteries and it ran fine. Share this post Link to post Share on other sites
JoeM 10,101 #19 Posted June 17, 2020 Glued those lines down in the groves and blew the vent line out with air, cut 1/2 and acre no issues. ?? will see. 1 Share this post Link to post Share on other sites
stevebo-(Moderator) 8,741 #20 Posted June 23, 2020 Anyone here know if I have to pull the motor in order to get to the intake gaskets? I have not looked hard but at quick look it may not be possible to remove tins on top to access in the tractor. Share this post Link to post Share on other sites
Shynon 7,604 #21 Posted June 23, 2020 You may be able to move the plate between engine and steering to access the flywheel cover and move it toward the steering shaft. To get to the intake bolts. Share this post Link to post Share on other sites
stevebo-(Moderator) 8,741 #22 Posted June 23, 2020 Thanks pal. Not looking forward to this job 1 Share this post Link to post Share on other sites
