The Tuul Crib 7,353 #26 Posted August 28, 2020 (edited) Sitting here listening to some Clint black music trying to get this charger back together. Started to venture on the starter of all things. Went out to the shed and grabbed two or three and brought in and ran a check on each one. Got one that works great cleaned it up put some paint on it and it's ready for installation! Edited August 28, 2020 by The Tuul Crib 1 Share this post Link to post Share on other sites
ebinmaine 78,239 #27 Posted August 28, 2020 Snazzy! Share this post Link to post Share on other sites
ebinmaine 78,239 #28 Posted August 28, 2020 Don't forget to clean the ground area..... Share this post Link to post Share on other sites
The Tuul Crib 7,353 #29 Posted August 28, 2020 Oh yea lots of Negativity! I drilled out and tapped an extra hole in the hubs as well and threaded for another bolt. 5 Share this post Link to post Share on other sites
ebinmaine 78,239 #30 Posted August 29, 2020 Likely a little late now but the hub should have a flat ground into it so the set screw jamb nut will be less prone to backing out. Share this post Link to post Share on other sites
The Tuul Crib 7,353 #31 Posted August 29, 2020 39 minutes ago, ebinmaine said: Likely a little late now but the hub should have a flat ground into it so the set screw jamb nut will be less prone to backing out. Thanks for the tip! Easy fix. Drilling and tapping was no probably. I'll have to get the grinder Out tomorrow and flatten that spot!Might still add a flat washer and a spring washer in that area as well Share this post Link to post Share on other sites
The Tuul Crib 7,353 #32 Posted September 2, 2020 Got home today and fully mounted all the tins. put all the small bolts back in place now I'm searching for a carburetor! 3 Share this post Link to post Share on other sites
ebinmaine 78,239 #33 Posted September 2, 2020 23 minutes ago, The Tuul Crib said: carburetor Call Lincoln and get a real Kohler. Rebuild that. Share this post Link to post Share on other sites
The Tuul Crib 7,353 #34 Posted September 2, 2020 33 minutes ago, ebinmaine said: Call Lincoln and get a real Kohler. Rebuild that. I have a good collection of carburetors in a plastic container got to go through all of them and find a good one. What diameter of port did you say it was for a 16 horse? Share this post Link to post Share on other sites
ebinmaine 78,239 #35 Posted September 2, 2020 23 minutes ago, The Tuul Crib said: I have a good collection of carburetors in a plastic container got to go through all of them and find a good one. What diameter of port did you say it was for a 16 horse? I think it's a 30.. Share this post Link to post Share on other sites
Stormin 9,987 #36 Posted September 2, 2020 On 8/29/2020 at 1:58 AM, The Tuul Crib said: Might still add a flat washer and a spring washer in that area as well I'd forget about a spring washer, Randy. Just use Loctite thread locker, or whatever similar you have over there. 1 Share this post Link to post Share on other sites
The Tuul Crib 7,353 #37 Posted September 12, 2020 Finally passed on from the transmission to the power plant .This 30 over 16 needs to be born one bolt at a time.Got the PTO cleaned up and painted. 4 1 Share this post Link to post Share on other sites
The Tuul Crib 7,353 #38 Posted September 12, 2020 Just got my decals today from @Vinylguyand I have to say I am absolutely excited and can't wait to put them on!!Excellent job my friend! 2 1 Share this post Link to post Share on other sites
