muz123 1,193 #1 Posted June 11, 2020 Over the years of using my 520H to mow grass, it has become a nuisance when the grass gets caught in the flywheel grass screen and you have to reach over and scrape it off so the engine won't overheat or the carb won't get dirty. Anyway to prevent it? Share this post Link to post Share on other sites
Ed Kennell 46,597 #2 Posted June 11, 2020 I can't find it, but I remember a thread on this problem. One guy added a 90 degree 10 or 12 " flue elbow to the intake. Share this post Link to post Share on other sites
roadapples 6,987 #3 Posted June 11, 2020 It has an inner screen that spins like the Kohler. Take the outer one off. The inner one will throw it off just like the Kohler.... 2 Share this post Link to post Share on other sites
953 nut 67,420 #4 Posted June 11, 2020 9 hours ago, muz123 said: Anyway to prevent it? When I changed from a side discharge deck to a rear discharge deck that problem went away. Share this post Link to post Share on other sites
lynnmor 8,902 #5 Posted June 11, 2020 The front tire can kick up much of that grass under some conditions. One guy on here fabricated a fender to help with the problem. Some old farm tractors had a shaker screen in front of the radiator, might be an idea for someone to develop. Share this post Link to post Share on other sites
Stormin 9,988 #6 Posted June 11, 2020 15 hours ago, roadapples said: It has an inner screen that spins like the Kohler. Take the outer one off. The inner one will throw it off just like the Kohler.... There's your answer. The outer grill will be there to keep the health and safety bods happy. Just in case you try and grab hold of the spinning screen. 1 1 Share this post Link to post Share on other sites
Lee1977 7,709 #7 Posted June 11, 2020 55 minutes ago, Stormin said: There's your answer. The outer grill will be there to keep the health and safety bods happy. Just in case you try and grab hold of the spinning screen. Your right it like that crazy plastic cover on the Classic 315 over the PTO and mule drive. 3 Share this post Link to post Share on other sites
bottjernat1 2,196 #8 Posted June 11, 2020 Yep a lawn sweeper while mowing Share this post Link to post Share on other sites
Sparky-(Admin) 25,940 #9 Posted June 11, 2020 21 hours ago, muz123 said: DANG! Looks like a tossed salad on the screen 1 4 Share this post Link to post Share on other sites
WHNJ701 4,173 #10 Posted June 11, 2020 get rid of the grass and put astro turf down 1 Share this post Link to post Share on other sites
tom2p 2,394 #11 Posted June 12, 2020 3 hours ago, jabelman said: get rid of the grass and put astro turf down ding ding ding - we gotta winner ! Share this post Link to post Share on other sites
tom2p 2,394 #12 Posted June 12, 2020 12 hours ago, lynnmor said: The front tire can kick up much of that grass under some conditions. agree - I see this happen as I cut grass Share this post Link to post Share on other sites
tom2p 2,394 #13 Posted June 12, 2020 (edited) On 6/10/2020 at 9:40 PM, muz123 said: Over the years of using my 520H to mow grass, it has become a nuisance when the grass gets caught in the flywheel grass screen and you have to reach over and scrape it off so the engine won't overheat or the carb won't get dirty. Anyway to prevent it? at one point I mounted a small snow brush on the left side cover with hook-and loop tape (Velcro) so I could brush away the grass and leaves without disengaging the PTO and reaching over/down to remove with hand this worked fairly well - but at times the grass / leaves would get sucked behind the blower housing guard - so I'm back to removing the stuff by hand Edited June 12, 2020 by tom2p 1 Share this post Link to post Share on other sites
echris 1,426 #14 Posted June 12, 2020 On 6/10/2020 at 9:40 PM, muz123 said: Over the years of using my 520H to mow grass, it has become a nuisance when the grass gets caught in the flywheel grass screen and you have to reach over and scrape it off so the engine won't overheat or the carb won't get dirty. Anyway to prevent it? I've just invented a solution. Already applied for a patent. You can thank me later. 2 1 Share this post Link to post Share on other sites
EricF 589 #15 Posted June 12, 2020 I've seen the rotating screens get covered up with grass clippings, too. In a nice swirl pattern. At least with a fixed screen, it's safe to lean over and brush the debris off while the engine is running -- can't do that with a rotating screen. To that end, I can well remember the JD 112 may family had when I was growing up. JD didn't use the normal Kohler rotating screen; they had it omitted, and instead put a fixed mesh screen over it that attached to the engine tin. It was easy to lean down and brush it off a few times while mowing. Very similar to the mesh screens that Kohler put on their twins. 1 Share this post Link to post Share on other sites
Lee1977 7,709 #16 Posted June 13, 2020 I've seen a brush install on an old Gravely garden tractor with a Kohler where the engine is over the rear hitch. Share this post Link to post Share on other sites
Ed Kennell 46,597 #17 Posted June 15, 2020 Here ya go... 1 3 Share this post Link to post Share on other sites
Stormin 9,988 #18 Posted June 16, 2020 7 hours ago, Ed Kennell said: Here ya go... That's not as daft as it looks. Something along the same idea. Up to the bottom of the bonnet side and detachable. 2 1 Share this post Link to post Share on other sites
