John2189 601 #51 Posted June 12, 2020 1 hour ago, formariz said: Want hard ones or easy ones? Your pick. Share this post Link to post Share on other sites
Mickwhitt 5,259 #52 Posted July 9, 2020 What are these little beauties for? I picked them up at an engineering show and no one knew what they were for. Only an inch long they are used in pairs. Mick 1 Share this post Link to post Share on other sites
Mickwhitt 5,259 #53 Posted July 9, 2020 This is a genuine I don't know what its for one. Some kind of key but for what? 5mm Square ⬛ hole in the end. The brass acorn shaped ends screw off as if to provide storage space, the little screw on top of the tee serves no apparent purpose other than for decoration. Made of blued steel and brass. 3 inch long x 2 inch wide 1 Share this post Link to post Share on other sites
ebinmaine 80,777 #54 Posted July 9, 2020 Couple good ones there Mick Share this post Link to post Share on other sites
John2189 601 #55 Posted July 10, 2020 15 hours ago, Mickwhitt said: What are these little beauties for? I picked them up at an engineering show and no one knew what they were for. Only an inch long they are used in pairs. Mick These look like stops you put on a carpenters square for repeated angles to make step runners 1 Share this post Link to post Share on other sites
John2189 601 #56 Posted July 10, 2020 (edited) 15 hours ago, Mickwhitt said: This is a genuine I don't know what its for one. Some kind of key but for what? 5mm Square ⬛ hole in the end. The brass acorn shaped ends screw off as if to provide storage space, the little screw on top of the tee serves no apparent purpose other than for decoration. Made of blued steel and brass. 3 inch long x 2 inch wide This looks like a key to a gas valve for a gas fire place. Is the top of the handle that the caps screw on hollow? If so that might be match storage Edited July 10, 2020 by John2189 Added 1 Share this post Link to post Share on other sites
Mickwhitt 5,259 #57 Posted July 10, 2020 Not hollow all the way through, a small space in each end. Share this post Link to post Share on other sites
Mickwhitt 5,259 #58 Posted July 10, 2020 Re the pair of tools they do clamp onto another engineering tool. Share this post Link to post Share on other sites
John2189 601 #59 Posted July 10, 2020 18 minutes ago, Mickwhitt said: Re the pair of tools they do clamp onto another engineering tool. Do they clamp onto vernier calipers for inside measure? Share this post Link to post Share on other sites
Mickwhitt 5,259 #60 Posted July 10, 2020 John, No, they do clamp onto a rule or measuring scale though. Milk Share this post Link to post Share on other sites
Mickwhitt 5,259 #61 Posted July 12, 2020 No more guesses? I will post a pic of them in use later on Mick Share this post Link to post Share on other sites
John2189 601 #62 Posted July 12, 2020 3 hours ago, Mickwhitt said: No more guesses? I will post a pic of them in use later on Mick Sorry. Out of ideas Share this post Link to post Share on other sites
Mickwhitt 5,259 #63 Posted July 12, 2020 This is a similar pair fitted to a six inch rule. Does that assist in identifying its use? Share this post Link to post Share on other sites
John2189 601 #64 Posted July 15, 2020 Ok just found a pair of these on eBay. They are key seat clamps. But not sure how to use them Share this post Link to post Share on other sites
Stormin 9,988 #65 Posted July 15, 2020 They are used to mark out keyways on round bars etc. Clamp a rule in them, place against the work piece and scribe a line along the rule. 2 1 Share this post Link to post Share on other sites
formariz 12,381 #66 Posted July 18, 2020 On 7/15/2020 at 5:38 AM, Stormin said: They are used to mark out keyways on round bars etc. Clamp a rule in them, place against the work piece and scribe a line along the rule. I am a little confused about this. One then just runs pencil or scribe along ruler to mark a straight line on round stock? Is that its intended function? Share this post Link to post Share on other sites
John2189 601 #67 Posted July 18, 2020 19 minutes ago, formariz said: I am a little confused about this. One then just runs pencil or scribe along ruler to mark a straight line on round stock? Is that its intended function? Me too. It could determine length of it. Share this post Link to post Share on other sites
formariz 12,381 #68 Posted July 18, 2020 I may be wrong but in a machinists world is there a need to layout something like that prior to machining? I thought all necessary stops and locations would be set on machinery so an ordinary pencil line would be unnecessary? Share this post Link to post Share on other sites
Mickwhitt 5,259 #69 Posted July 28, 2020 It is indeed a pair of key seat clamps, used to hold a ruler so keyways can be measured on round bar. Not for setting out so much as for accuracy in measuring in line with the axis of the shaft. Sorry I missed these posts as notifications didn't pop up. Share this post Link to post Share on other sites
Mickwhitt 5,259 #70 Posted July 28, 2020 How about this one? Share this post Link to post Share on other sites
ebinmaine 80,777 #71 Posted July 28, 2020 That says bottle cap opener to me but that's probably not the actual use for it Share this post Link to post Share on other sites
Mickwhitt 5,259 #72 Posted July 29, 2020 Bang on Eric, this is a Cortu, magnetuc bottle cap lifter. British patent from the 1950s. Found it in a box of junk on its way to the tip. 1 Share this post Link to post Share on other sites
ebinmaine 80,777 #73 Posted July 29, 2020 1 hour ago, Mickwhitt said: Bang on Eric, this is a Cortu, magnetuc bottle cap lifter. British patent from the 1950s. Found it in a box of junk on its way to the tip. Well I'll be.... Share this post Link to post Share on other sites
