nfg 2 #1 Posted June 7, 2020 I rebuilt my mower deck. replaced it. and now my oil pressure swich blinks on the panel. Where is the switch located Share this post Link to post Share on other sites
pfrederi 20,994 #2 Posted June 7, 2020 What model WH do you have?? 1 Share this post Link to post Share on other sites
lynnmor 8,970 #4 Posted June 8, 2020 It is on the oil filter mount under the engine tin. Does it blink while the engine is running? If so, you need to keep the engine off till the oil pressure is checked. Share this post Link to post Share on other sites
nfg 2 #5 Posted June 8, 2020 it blinks when the key is on. But will not crank Share this post Link to post Share on other sites
lynnmor 8,970 #6 Posted June 8, 2020 1 hour ago, nfg said: it blinks when the key is on. But will not crank The blinking with the engine not running is normal, you have a starting circuit issue. Check the PTO and seat switches, a temporary bypass will help diagnose. Download the Demystification Guide in the manuals section to help you with the issue. Report back. Share this post Link to post Share on other sites
1995 520H+96+97 939 #7 Posted June 8, 2020 Which light is lite up when you turn key to start? Share this post Link to post Share on other sites
nfg 2 #8 Posted June 9, 2020 the problem was the seat switch. It was corroded cleaned it up. I greatly appreciate the help 1 Share this post Link to post Share on other sites
