John2189 573 #1 Posted June 3, 2020 Hi. Is there a registry or stroke adjustment on this mower? The stroke is not even And it clogs up. And doesn’t cut very well. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,015 #2 Posted June 3, 2020 Do not know what you are asking Garry Share this post Link to post Share on other sites
WHX?? 55,237 #3 Posted June 3, 2020 No there is no adjustment on stroke. If your wobble box bushings are worn you will not get full length strokes and cutters must be razor sharp. Check the point where the bar connects to wobble shaft. Very common point of wear there even if kept greased. Guess I don't mean what you mean by registry??? 1 Share this post Link to post Share on other sites
John2189 573 #4 Posted June 3, 2020 1 hour ago, WHX24 said: No there is no adjustment on stroke. If your wobble box bushings are worn you will not get full length strokes and cutters must be razor sharp. Check the point where the bar connects to wobble shaft. Very common point of wear there even if kept greased. Guess I don't mean what you mean by registry??? Registry. Just another word for stroke 2 Share this post Link to post Share on other sites
pfrederi 19,960 #5 Posted June 3, 2020 Registry on a sickle means that the direction reverses when the section (aka cutter blade) is directly over the stone guard. Reversing direction when they are not in alignment causes jamming poor cutting etc. 1 1 Share this post Link to post Share on other sites
John2189 573 #6 Posted June 3, 2020 2 hours ago, pfrederi said: Registry on a sickle means that the direction reverses when the section (aka cutter blade) is directly over the stone guard. Reversing direction when they are not in alignment causes jamming poor cutting etc. Thanks for the better explanation john Share this post Link to post Share on other sites
