WVHillbilly520H 10,369 #26 Posted June 2, 2020 13 hours ago, PeacemakerJack said: Jeff...tell us about that white plate on your dad’s plow. The way that is slotted, looks to me like that would afford some level of suck point adjustment. You definitely need to get that thing in the ground and polished up😉. I love the shape of that sod bottom, reminds me a lot of my dad’s old Bolens plow. Sorry Josh been busy with a a Yellow and White project... The white plate on the plow was made by my dad many moons ago (at the sheet metal factory he worked at) so that cast iron beam could be bolted to the Brinly clevis... Just a few years back I took that plate to where I worked and added the slots and bent/tweaked it some more until it laid flat behind my 520 while the right side tires were on boards so yeah I guess you could have a couple 3/4" wrenches and adjust the "suck" a little bit when necessary... Not quite as easy as the Brinly... Also dad made the replacement share... I was going to flap wheel it then oil it down. 2 1 Share this post Link to post Share on other sites
Dan.gerous 2,696 #27 Posted June 2, 2020 The courier has just picked up my Plow from its previous owner! Delivery is Thursday the same day I have to head back to Aberdeen and join my ship so I will just miss it. Damn nuisance as was going to take it onboard and clean it up in my free time, it can be quite boring stuck onboard when I have better things to do at home. 3 Share this post Link to post Share on other sites
Dan.gerous 2,696 #28 Posted June 4, 2020 (edited) The kids kindly sent me a picture of the plow sitting behind one of the wheel horses - it turned up about three hours after I left for work. Edited June 4, 2020 by Dan.gerous 4 1 Share this post Link to post Share on other sites
Achto 26,573 #29 Posted June 4, 2020 (edited) I see that your tractor is protected by an attack chicken. Edited June 4, 2020 by Achto 3 Share this post Link to post Share on other sites
Dan.gerous 2,696 #30 Posted June 4, 2020 29 minutes ago, Achto said: I see that your tractor is protected by an attack chicken. I have ten attack chickens keeping it safe! 1 2 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 10,503 #31 Posted June 4, 2020 If you want to plow 5 inches deep place 5 inch blocks under the front and rear left tractor tires. Place the plow at the rear of the tractor like in the photo. Then you can see what you need to do to join the two. If a bit of adjustment can be built into the hitch you will be able to fine tune it. Garry 1 1 Share this post Link to post Share on other sites
Dan.gerous 2,696 #32 Posted June 4, 2020 3 hours ago, gwest_ca said: If you want to plow 5 inches deep place 5 inch blocks under the front and rear left tractor tires. Place the plow at the rear of the tractor like in the photo. Then you can see what you need to do to join the two. If a bit of adjustment can be built into the hitch you will be able to fine tune it. Garry You must have read my mind, was about to ask that very question! Share this post Link to post Share on other sites
Dan.gerous 2,696 #33 Posted June 6, 2020 So can anybody explain what the disc is for on the plow? I'm assuming it's to stop things getting hooked on the blade? Share this post Link to post Share on other sites
Dan.gerous 2,696 #34 Posted June 16, 2020 I just brought a different kind of plow, this time managed to pick up a nice condition snow plow. Haven't even been home yet to have a look at the plough that started this thread! The owner also has a 48" side discharge deck and a bunch of parts for me 😁 Starting to get lots of attachments now, thought it would take a lot longer. 1 3 Share this post Link to post Share on other sites
ebinmaine 63,211 #35 Posted June 16, 2020 NIIIIIICE 1 Share this post Link to post Share on other sites
WHX?? 46,810 #36 Posted June 16, 2020 My neck was getting sore Dan. You will need the axle bracket too I don't see that? 1 Share this post Link to post Share on other sites
Dan.gerous 2,696 #37 Posted June 16, 2020 6 minutes ago, WHX24 said: My neck was getting sore Dan. You will need the axle bracket too I don't see that? That's better, didn't even think to turn them around. Yeah, I do have an axle bracket for my Rototiller, but hopefully this will have one as well so I can swap between machines if required. 1 Share this post Link to post Share on other sites
ebinmaine 63,211 #38 Posted June 17, 2020 2 hours ago, Dan.gerous said: axle bracket If not you can make one from rugged angle iron. 1 Share this post Link to post Share on other sites
WHX?? 46,810 #39 Posted June 17, 2020 Bracket should be the same Dan. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 10,503 #40 Posted June 17, 2020 On 6/5/2020 at 11:59 PM, Dan.gerous said: So can anybody explain what the disc is for on the plow? I'm assuming it's to stop things getting hooked on the blade? The disc is called a coulter and cuts the sod just before the mouldboard turns it over. Garry 1 1 Share this post Link to post Share on other sites
Dan.gerous 2,696 #41 Posted June 17, 2020 4 hours ago, gwest_ca said: The disc is called a coulter and cuts the sod just before the mouldboard turns it over. Garry Thanks Gary, will be more questions once I get home and start trying to mount the plough onto the tractor. I can see that taking a back seat for a day now I have the snow plow! Share this post Link to post Share on other sites
Dan.gerous 2,696 #42 Posted June 17, 2020 6 hours ago, ebinmaine said: If not you can make one from rugged angle iron. Good idea, it starts getting expensive quickly when you have to keep buying these little bits and pieces. 1 Share this post Link to post Share on other sites
ebinmaine 63,211 #43 Posted June 17, 2020 1 hour ago, Dan.gerous said: Good idea, it starts getting expensive quickly when you have to keep buying these little bits and pieces. I made up a set of them using the locking levers from an old original bracket. I used 2 pieces of a Wheelhorse frame. I did that because I needed to move the whole plow forward a bit to clear the oversized front tires and it gave me the ability to leave the hitch on year round because I changed the way it bolted on. Share this post Link to post Share on other sites
Dan.gerous 2,696 #44 Posted June 18, 2020 On 6/17/2020 at 9:24 AM, ebinmaine said: I made up a set of them using the locking levers from an old original bracket. I used 2 pieces of a Wheelhorse frame. I did that because I needed to move the whole plow forward a bit to clear the oversized front tires and it gave me the ability to leave the hitch on year round because I changed the way it bolted on. You know the rules, pictures 😊 1 Share this post Link to post Share on other sites
Dan.gerous 2,696 #45 Posted June 18, 2020 Just got home, had a first look at the plow. It's got adjustment on the front to change the angle - see pics. That's got to be a good thing. Share this post Link to post Share on other sites
ebinmaine 63,211 #46 Posted June 18, 2020 29 minutes ago, Dan.gerous said: You know the rules, pictures 😊 I know there's a thread on here somewhere that has them but I don't remember if it's separated or in a common Thread. I'll either find a couple pictures or take some more for you. 1 Share this post Link to post Share on other sites
ebinmaine 63,211 #47 Posted June 21, 2020 On 6/18/2020 at 12:31 PM, Dan.gerous said: You know the rules, pictures 😊 Here's a shot of the right side bracket. Left is same size/shape but opposite built. 1 Share this post Link to post Share on other sites
Dan.gerous 2,696 #48 Posted June 21, 2020 1 hour ago, ebinmaine said: Here's a shot of the right side bracket. Left is same size/shape but opposite built. Thanks, that is so simple but effective. 1 Share this post Link to post Share on other sites
