Rustyred 63 #1 Posted May 23, 2020 Please Advise: My Kohler K181 on my C-81 has been running well. When I fired it up a couple days ago it started blowing white smoke from the exhaust. I thought it would go away after it warmed up but it doesn't! Throttle up and there's more smoke. I know the fuel is fine because it's new. But the smoke doesn't stop. Something is wrong - what do I do? Share this post Link to post Share on other sites
953 nut 68,917 #2 Posted May 23, 2020 Sounds like you may have a plugged up crankcase vent or a broken piston ring. The vent plate is behind the carburetor, pull it off and clean it well and replace the filter. The best way to check the piston rings is with a leak-down test. https://www.wheelhorseforum.com/search/?&q=leakdown&type=downloads_file&search_and_or=or&sortby=relevancy Share this post Link to post Share on other sites
squonk 48,012 #3 Posted May 24, 2020 Check your oil for fuel dilution too 1 Share this post Link to post Share on other sites
richmondred01 2,389 #4 Posted May 25, 2020 like squonk said: If this just started I would check the crank case oil and see if the fuel pump is leaking gas into the engine. that’s an easy first start. pull the stick and smell if for gas. Share this post Link to post Share on other sites
