danweikert21 166 #1 Posted May 18, 2020 Just am wondering does the ground wire from my starter solied go dircetly to the battery or somewhere else. I'm new to this so wanted to make sure Im doing it right. Share this post Link to post Share on other sites
Pullstart 68,517 #2 Posted May 18, 2020 Ground wires aren’t too picky as long as they have good connections. Straight to the battery is a perfect spot though! what tractor are you working on? 2 Share this post Link to post Share on other sites
squonk 44,856 #3 Posted May 18, 2020 How many posts are on your solenoid? What model tractor? Most solenoids ground thru the solenoid body. 1 big terminal from the battery positive, the other big terminal to the starter. Small post to the key switch. 2 Share this post Link to post Share on other sites
danweikert21 166 #4 Posted May 20, 2020 Im working on a Raider 10 model 1-6041 which would normally have a Tecumseh HH-100 but I got a kohler K 241 and rewired it. 2 Share this post Link to post Share on other sites
danweikert21 166 #5 Posted May 20, 2020 On 5/18/2020 at 2:05 PM, squonk said: How many posts are on your solenoid? What model tractor? Most solenoids ground thru the solenoid body. 1 big terminal from the battery positive, the other big terminal to the starter. Small post to the key switch. My solenoid is has two big post and then two small posts on for the key and one for the ground. The reason I have to ground it is because the soliod is on the engine itself. Thank you for helping me with this Share this post Link to post Share on other sites
peter lena 9,552 #6 Posted May 20, 2020 i have also added a battery size cable from my engine base bolt to my dash/ console area , insuring solid grounding. done that on my three horses , and electrical issues are gone, pete Share this post Link to post Share on other sites
D_Ram 17 #7 Posted July 2, 2020 On 5/20/2020 at 8:50 AM, danweikert21 said: Im working on a Raider 10 model 1-6041 which would normally have a Tecumseh HH-100 but I got a kohler K 241 and rewired it. Do you still have the HH100 and parts? Share this post Link to post Share on other sites
