Rosco 11 #1 Posted May 11, 2020 Finally getting around to restoring RJ 58 it has a 4 Hp Clinton motor I would like to rebuild the carburetor so I'm looking for carburetor rebuild kit and I also know noticed the carburetor Bowl is toast. Does anyone know if I can still get parts for this bad Larry I'm sure this is just the tip of the iceberg. Can you still get head gaskets Rings valve if anyone could steer me in the right direction for getting parts and manuals I would deeply appreciate it Thanks Rosco Share this post Link to post Share on other sites
Stepney 2,354 #2 Posted May 11, 2020 Can you get a photo of the carb? Some Clintons used a Tillotson, some had a Carter. I've owned dozens of those engines. May have some parts. Share this post Link to post Share on other sites
formariz 12,051 #3 Posted May 11, 2020 19 minutes ago, Rosco said: Finally getting around to restoring RJ 58 it has a 4 Hp Clinton motor I would like to rebuild the carburetor so I'm looking for carburetor rebuild kit and I also know noticed the carburetor Bowl is toast. Does anyone know if I can still get parts for this bad Larry I'm sure this is just the tip of the iceberg. Can you still get head gaskets Rings valve if anyone could steer me in the right direction for getting parts and manuals I would deeply appreciate it Thanks Rosco We have here a member Charlie that goes by the name of @clintonnut. He is the resident expert on Clinton engines. Not only is he extremely capable but an all around great guy. Perhaps you can PM him or he will be checking in although I don't think he has been around much. And most likely he will have one already totally rebuilt for you should you decide to go that way. I personally own a couple rebuilt by him. Share this post Link to post Share on other sites
Rosco 11 #4 Posted May 12, 2020 42 minutes ago, Stepney said: Can you get a photo of the carb? Some Clintons used a Tillotson, some had a Carter. I've owned dozens of those engines. May have some parts. Share this post Link to post Share on other sites
Rosco 11 #5 Posted May 12, 2020 Thanks for getting back to me 1 Share this post Link to post Share on other sites
oliver2-44 10,831 #6 Posted May 12, 2020 If you don't find a carb bowl, you can probable repair yours. I've repaired an aluminum kohler bowl that was pitted through with JB Weld. it's been in service for a year and no leaks. I've read of others doing this as well. Share this post Link to post Share on other sites
WHX?? 52,231 #7 Posted May 12, 2020 Here is some more contact info for Clinton parts http://www.clintonengines.us/Parts.html Share this post Link to post Share on other sites
buckrancher 2,695 #8 Posted May 12, 2020 you can find all the parts on e-bay they are common among the Clinton styled carbs Share this post Link to post Share on other sites
SMITTY 23 #9 Posted May 15, 2020 Dose anyone have a picture of the throttle, governor set up? Took mine apart and doesn't work correctly Thanks Smitty Share this post Link to post Share on other sites
Rosco 11 #10 Posted June 16, 2020 Sory RJ is all A Pile crap just getting the last of the paint . Hope I remember how to put it back together. Still waiting on points. If and whe I get it back up and running I will takes some pic. Share this post Link to post Share on other sites
