John2189 563 #26 Posted May 12, 2020 Ok found the I’d tag under the dashboard. model. T656 serial 17556 1 1 Share this post Link to post Share on other sites
953 nut 64,108 #27 Posted May 12, 2020 1 hour ago, John2189 said: Ok found the I’d tag under the dashboard. model. T656 serial 17556 Yes, 6 (six HP) 5 (electric start/manual shift) 6 (made in 1966) 2 Share this post Link to post Share on other sites
John2189 563 #28 Posted May 12, 2020 Thanks for all the help. Now to get it running. john Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,998 #29 Posted May 12, 2020 3 hours ago, John2189 said: Ok found the I’d tag under the dashboard. model. T656 serial 17556 Think you are missing one digit in the serial number. Garry Share this post Link to post Share on other sites
John2189 563 #30 Posted May 12, 2020 Yes I missed a 1 1 Share this post Link to post Share on other sites
WHX?? 54,958 #31 Posted May 12, 2020 Sorry John I can't stand on my head like I used to..... 2 Share this post Link to post Share on other sites
John2189 563 #32 Posted May 12, 2020 Do you have a registry for these tractors? Share this post Link to post Share on other sites
John2189 563 #33 Posted May 12, 2020 5 minutes ago, WHX24 said: Sorry John I can't stand on my head like I used to..... Yes I didn’t notice it up side down until I sent it. Thanks for fixing it. Now can you fix this tractor? 😁 1 Share this post Link to post Share on other sites
953 nut 64,108 #34 Posted May 12, 2020 5 minutes ago, John2189 said: Do you have a registry for these tractors? Garry @gwest_ca logs all known serial numbers on the same page as the owner's manuals. 1 Share this post Link to post Share on other sites
WHX?? 54,958 #35 Posted May 12, 2020 12 minutes ago, John2189 said: Now can you fix this tractor? … Techy??? yer on yer own! Share this post Link to post Share on other sites
John2189 563 #36 Posted May 12, 2020 16 minutes ago, WHX24 said: … Techy??? yer on yer own! Hey, I tried 😁 1 Share this post Link to post Share on other sites
John2189 563 #37 Posted May 13, 2020 Ok got the motor running. No smoke sounds good. Sickle works pretty good. Need to buy a new battery and all 4 tires now to get the c 165 running. again thanks for all the help. john 1 Share this post Link to post Share on other sites
John2189 563 #38 Posted May 15, 2020 On 5/13/2020 at 2:43 PM, John2189 said: Ok got the motor running. No smoke sounds good. Sickle works pretty good. Need to buy a new battery and all 4 tires now to get the c 165 running. again thanks for all the help. john Ok got the c165 running. Replaced broken connecting rod and since I pulled the piston new rings. john Share this post Link to post Share on other sites
