69mach 10 #1 Posted May 8, 2020 Hello all. I have a 94 520-H that I can't seem to figure out to level the 48" mower deck in the up position, crooked as all hell & cannot figure it out. Share this post Link to post Share on other sites
lynnmor 9,051 #2 Posted May 8, 2020 Side to side or front to rear? Is the deck mounted correctly? The owners manual is here. 1 Share this post Link to post Share on other sites
69mach 10 #3 Posted May 8, 2020 32 minutes ago, lynnmor said: Side to side or front to rear? Is the deck mounted correctly? The owners manual is here. Yes mounted correctly & its side to side. I will take a picture tomorrow. Left side is down a few inches. Does not hit stops. Share this post Link to post Share on other sites
lynnmor 9,051 #4 Posted May 8, 2020 There may be damage to the parts that hold it up. Did you adjust the transport height using the nut that is accessed after removing vertical the plate on the console? Did you adjust the stops to the lowest setting? 1 Share this post Link to post Share on other sites
