jerry potaracke 3 #1 Posted May 4, 2020 would anybody have an idea why my d160 transmission oil temp gauge pegs out when i turn the ignition key to the on position?? even tho the tractor hes not been running.thanks Share this post Link to post Share on other sites
pfrederi 20,629 #2 Posted May 4, 2020 Could be a short in the wiring but most likely the gauge or the sending unit has died...Disconnect eh lead from the sending unit. Use your multimeter to read resistance from the terminal on the sending unit to ground. Thne start her up and run her around for awhile. Then shut it down and repeat the reading. if resistance stays the same sending unit is bad if it changes then gauge is bad. 1 Share this post Link to post Share on other sites
jerry potaracke 3 #3 Posted May 4, 2020 i am looking for the transmission temperature sending unit. can you describe it and its location thank you . Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,264 #4 Posted May 4, 2020 Found this in Section 5 of this service manual. Click on the picture to see what is in each Section. Garry Share this post Link to post Share on other sites
jerry potaracke 3 #5 Posted May 5, 2020 yes sir it is the temperature sending unit the stud spins in the back of the unit is this something i can purchase at oreillys auto thanks for all your help Share this post Link to post Share on other sites
pfrederi 20,629 #6 Posted May 5, 2020 Sending units have to be matched to the gauge they are running. Your best bet buy a new gauge and will come with correct sending unit. Get an electrical one most mechanical gauge sending units will not fit in the hydro pump. Something like this Share this post Link to post Share on other sites
